balanced and blueprinted....
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
blueprinting is a little bit more than putting things within the factory specs. it means putting everything within each related parts specs. such as, piston to cylinder clearance, make them all one number, prefferably the most desirable one. very expensive, as you might have to purchase multiple copies of parts.
stan
stan
I kinda have an add on question about balancing.
So how will this affect the crank if you were to upgrade to a set of light weight rods and pistions.
Even so if they were all matched wouldint the counter balanced weights on the crankshaft be too much for the new lighter stuff?
Or are the counter weights on the crankshaft just there for balancing the crankshaft itself?
Johnny_9
69
Mar 10, 2011 03:09 PM
