bad water pump??
Old Jan 23, 2007 | 08:45 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default bad water pump??
well the other day i was driving my wagon and it got hot. so i stop and look around a bit..well the lower hose was cold..so i think to myself bad thermostat WRONG i put 1 in and dose the same ****..so got another new one same thing.. then i take out the T-stat all together and the the water flows in the rad fine then. so what im thinking is that the fins are not spinning enough to push the water past the T-stat after it opens.. what you think??
Old Jan 23, 2007 | 10:27 PM
skunk_duece's Avatar
your flux capacitor is broke
Old Jan 24, 2007 | 07:29 AM
JimBlake's Avatar
Default Re: bad water pump?? (1QwIkEf)
T-stat in backwards?
T-stat gasket farbed up so it obstructs flow?
Garbage-brand T-stat?? Try OEM...
It's possible for the blades of the waterpump to be corroded away, but it's not real likely. So you want to rule out anything else before you spend a day removing the waterpump.
Old Jan 24, 2007 | 09:28 PM
1QwIkEf's Avatar
Default Re: bad water pump?? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">T-stat in backwards?
It's possible for the blades of the waterpump to be corroded away, but it's not real likely. So you want to rule out anything else before you spend a day removing the waterpump.</TD></TR></TABLE> im going to get a oem honda and try that..also i should say that it a NEW WATER PUMP but its not a oem honda
Old Jan 25, 2007 | 04:56 AM
JimBlake's Avatar
Hard to imagine what makes a waterpump fail. After all it's just a wheel with blades. Long-term corrosion is about it. Failed waterpump bearings make noise & are obvious from the pulley rattling around.
On OEM anyway, the T-stat gasket has a split in the inside, so it fits over the edge & covers both sides of the T-stat. If you use it like an O-ring on only one side, I imagine it can obstruct the T-stat action?
Old Jan 25, 2007 | 07:41 PM
1QwIkEf's Avatar
im going to buy a oem T-stat
Old Jan 27, 2007 | 09:59 PM
1QwIkEf's Avatar
Old Jan 28, 2007 | 06:50 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf &raquo;</TD></TR><TR><TD CLASS="quote">im going to buy a oem T-stat</TD></TR></TABLE>Did that work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf &raquo;</TD></TR><TR><TD CLASS="quote">..also i should say that it a NEW WATER PUMP but its not a oem honda </TD></TR></TABLE>Did you notice anything about that pump, like how it fit into the engine? Was the impeller the same size? Or maybe the shape of the vanes?
A non-OEM waterpump isn't always bad.
Old Jan 28, 2007 | 07:00 PM
1QwIkEf's Avatar
well i put it in over the summer and never had a prob with it getting hot..then when it started to get cold out it did this. its almost like the t stat never opens<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Did that work?
A non-OEM waterpump isn't always bad.</TD></TR></TABLE>
Old Feb 1, 2007 | 08:56 PM
Danronian's Avatar
Same prob I had with my integra, head gasket is the culprit I'd bet.
Old Feb 1, 2007 | 09:05 PM
1QwIkEf's Avatar
Default Re: (Danronian)
humm..did it smoke or don any crazy ****???
Old Feb 1, 2007 | 09:36 PM
pull the head J, that way you'll know and have access to everything else at the same time.
Old Feb 2, 2007 | 12:44 PM
Danronian's Avatar
Default Re: (1QwIkEf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf &raquo;</TD></TR><TR><TD CLASS="quote">humm..did it smoke or don any crazy ****???</TD></TR></TABLE>
Not a bit. It only started to act like the t-stat was stuck or broken...and I did also replace it with one of those "no fail" ones. So I know that wasnt it. I'm betting this is wrong with yours too. The machine shop I took my head to said hondas often run for years on blown head gaskets and don't show any symptoms. Mine had two blown cylinders when it was all apart...and it never smoked a BIT!
Old Feb 4, 2007 | 08:27 PM
1QwIkEf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian &raquo;</TD></TR><TR><TD CLASS="quote">Not a bit. It only started to act like the t-stat was stuck or broken...and I did also replace it with one of those "no fail" ones. So I know that wasnt it. I'm betting this is wrong with yours too. The machine shop I took my head to said hondas often run for years on blown head gaskets and don't show any symptoms. Mine had two blown cylinders when it was all apart...and it never smoked a BIT!</TD></TR></TABLE>well well well i pulled the water pump today..it was fine..i went to put the timing belt back on and lifted the vc off and what do you know a damn blown head gasket..oil was all milky anyone ever had any problems with buddy club head gaskets?
Old Feb 5, 2007 | 04:35 AM
mmmm stroganoff.
You know it doesn't take much of a surface imperfection on the head for it to go. Especially on your aftermarket HG, that aren't as forgiving as your everyday Fel-Pro gaskets. I always used Fel-pros copper HG on all my performance apps with no problems ever, but I never ran one on a Honda motor, but if it is available I would definitely look into it. They were specifically designed for use on V-8 supercharged applications. But I'd check the head for warpage as well.
Old Feb 5, 2007 | 12:25 PM
Danronian's Avatar
The machine shop I took my head to said most honda heads need to be resurfaced when the headgasket blows. He said mine was out a bit but it didn't take very much to be taken off of it to make it perfect. I'd suggest getting the head shaved a bit to make sure it isn't warped...only costs like $40 + cleaning.
Old Feb 5, 2007 | 02:01 PM
If I remeber correctly he had .005 taken off the head, and used ARP studs. To have actual mixture in with the oil to the point he sees the stroganoff, considering how long he's been runnin the set-up it would have had to either been a small leak from the beginning that eventually overcame the mixture, or a major blow near a water port that recently happened. I've pulled heads on D series before with cylinders filled and nothing in the oil.
Old Feb 5, 2007 | 08:13 PM
1QwIkEf's Avatar
Default Re: (skunk_duece)
ok..im putting my milled gsr head on it .020 off that and A 1 layer head gasket..lol i hope this 1 layer hold up..i guess we will see
Old Feb 6, 2007 | 10:08 PM
jesus loves the single layer headgasket...all the single headgaskets of the world!!!
cstap
Oct 10, 2013 06:34 AM
tony_yang
Honda Civic (2006 - 2015)
Jan 28, 2011 03:49 PM
crxsi8
10
Aug 30, 2005 10:49 PM
spaceman
Apr 21, 2004 06:17 AM
RenoRacing
Oct 28, 2002 04:52 AM
