Bad Speed Sensor..need help!
Old Sep 26, 2010 | 05:35 PM
Burnin93Octane's Avatar
Icon2 Bad Speed Sensor..need help!
I just bought a new speed sensor for my 95 honda civic eg, and my speedo still does nothing, what is the next thing to check for? the cables? a fuse? i need to get this thing working so any help would be much appreciated.
Old Sep 26, 2010 | 08:08 PM
megomaniac's Avatar
Default Re: Bad Speed Sensor..need help!
check to see if the drive gear for the sensor is in the trans, it's on the diff, should be able to see it with a flash light or feel for it with a screw driver.
happened to me, had a after market diff install and the shop forgot to install the drive gear on the diff, so i had to pull out the trans again, not cool. this was prelude trans, similar?
Old Sep 27, 2010 | 10:38 AM
yea the drive gear sensor is in the trans, that is the piece that I just purchased...all of that is new, except the cable and possibly needs a new fuse but i have no idea where to find the fuse for my VSS..
Old Sep 30, 2010 | 07:41 AM
tunedX's Avatar
I have the same trouble. My tacho is working though. I cleaned the plugs, also took apart the upper part of the sensor and cleaned. But no luck so far
Old Sep 30, 2010 | 08:37 AM
92cxhatch169's Avatar
i just replaced mine on my 00 si. works fine. but one of the techs at my work told me if it wasnt the speed sensor the speedo part of the cluster could have gone bad. was it bouncing around at all or just flat out quit working?
Old Oct 3, 2010 | 09:47 AM
It hasnt been working since i bought the car so I cant tell you what happened once it died out..or if it was ever working to begin with, It has a swapped motor and wiring harness so im replacing the wire harness with a brand new one, hopefully thatll do the trick.
Old Oct 3, 2010 | 10:39 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Id say you have a bad speedometer. Early to mid 90s Hondas (All models) have cluster issues.
Old Oct 6, 2010 | 01:16 PM
could also be true..once i recieve my new engine wire harness im going to check that next
kizen13
Transmission & Drivetrain
Sep 20, 2017 10:31 AM
b frisco
Mar 5, 2008 10:11 PM
boostedteg15
Mar 8, 2006 10:19 AM
sacjdmz
Mar 20, 2005 09:40 PM
Looose_R
Mar 27, 2002 04:49 PM
