Bad o2 sensor?
Old Oct 25, 2004 | 08:23 AM
AllMotorDA9's Avatar
Default Bad o2 sensor?
Need some serious help. I just swapped a b20b into a 90' DA. Im having a problem with running way to rich. Once i start the car (when its cold) it will just run like total *** and die. After it warms up it will idle descent w/o dying. I attempted to turn down the fuel psi on my b&m regualtor but still wont run any leaner. I know for a fact that my plugs are fouled from running this rich, so that cant be helping me any. So i have come to the conclusion that my o2 sensor is toast, its so bad that its telling the ecu to run way rich cuase it thinks that its running lean. So i plan on replacing the o2 sensor, plugs and resetting the ECU so hopefully it will recognize that it shouldnt be dumping so much fuel.
This is a daily beater and i needs a ride y0. Any suggestions?
Old Oct 25, 2004 | 08:56 AM
Default Re: Bad o2 sensor? (OneSlowDA)
bump for any ideas
Old Oct 25, 2004 | 09:06 AM
rev-speed's Avatar
when u first start up ur car
its in open loop
there 4 its not useing ur o2 to correct fuel trim
which injectors did u run?
Old Oct 25, 2004 | 09:59 AM
Default Re: (4cylinder)
What do you mean by open loop? Im using my stock obd0 injectors.
Old Oct 25, 2004 | 12:03 PM
Default Re: (OneSlowDA)
can i get a bump!
Old Oct 26, 2004 | 08:57 AM
Just wanted to say it bogs and sputters till 3k and anything after 3k it runs like a champ.
Old Oct 26, 2004 | 09:04 AM
Redsun's Avatar
If it runs good when warm then i think it'll be something with your purge and IACV. I dont know anything about DA and B20B's but if it's a hybrid then you must be missing something in this field.
Old Oct 26, 2004 | 09:20 AM
rev-speed's Avatar
open loop means ur ecu is paying no attention to ur o2 reading
only under close loop ur ecu will adjust fuel trim according to o2
(runs like a champ after 3k)on part throttle or full?
does ur car idle up to 1500 on cold start up?
Old Oct 26, 2004 | 10:24 AM
at any throttle after 3k its ok.
I dont have a FICV (skunk2 i/m) it was removed when the skunk2 was put on. So the rpms cant stay up so it just dies due to all the fuel loading up.
Maxime
Dec 24, 2004 07:13 AM
AllMotorDA9
Oct 26, 2004 06:27 AM
spencedogg
27
Nov 20, 2003 04:20 PM
NuclearB18B
Nov 7, 2003 09:33 PM
89 CRX SI
Dec 7, 2002 06:25 AM
