bad mileage, sputtering acceleration, backfire...help please!
Old Jun 19, 2003 | 03:55 PM
  #26
notstock93's Avatar
Default Re: bad mileage, sputtering acceleration, backfire...help please! (polyphony_digital)
check your vacuum lines, not the MAP sensor itself. I have the EXACT problem since i put in my crower 404's. make sure the lines arent cracked, either. MAP sensors usually dont just go bad. Of course, it maight have gone bad....how much was this guy boosting?
Old Jun 19, 2003 | 04:15 PM
  #27
polyphony_digital's Avatar
Default Re: bad mileage, sputtering acceleration, backfire...help please! (notstock93)
6.5-8 lbs I think...not too much...
I'll check that out...btw, I realized that there wasn't a seal under the MAP sensor, it didn't fix it with my sensor (when I put a seal in), but I just borrowed another sensor to try, I'll let you know...
Old Jun 19, 2003 | 04:26 PM
  #28
tinkerbell's Avatar
Default Re: bad mileage, sputtering acceleration, backfire...help please! (Bontke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bontke &raquo;</TD></TR><TR><TD CLASS="quote">A back fire is from unburned gas molecules igniting in the exhaust from high temps. You hae to have a rich mixture to do that or a weak ignition system.</TD></TR></TABLE>
(or leaking injectors in an extreme case)
dude, try to swap your MAP sensor with someone elses and see if that fixes it.
if it doesnt then you could have a broken connection between the MAP sensor and the ECU...
t..
Old Jun 19, 2003 | 05:51 PM
  #29
Default Re: bad mileage, sputtering acceleration, backfire...help please! (tinkerbell)
I used another MAP sensor, and the same **** happens...
Checked all the vaccuum lines, and they look new...
So it must be the wiring I guess...any reconmendations on where I should start? Check all of the wires between the MAP and the ECU? thanks.
Modified by polyphony_digital at 7:20 PM 6/19/2003
Old Jun 22, 2003 | 04:26 PM
  #30
threw some fuel injector cleaner in there, ran it all through and the gas mileage is better (not perfect, but better)....
again, any suggestions on the wiring? maybe I should just dive in and see if everything looks plugged in? thanks
Old Jun 22, 2003 | 04:28 PM
  #31
tinkerbell's Avatar
yeah, a visual inspection should be first... look for breaks, cuts or simply unpluged wires... make sure hte ECU connection is in firm and not damaged etc...
you say converted top OBD1 - with a harness or what?
it woudl be a place to check too...
t..
w4kj4k
Dec 13, 2008 08:23 PM
iwantturbo
Feb 5, 2006 09:56 AM
vtNaMeSe
Mar 21, 2004 12:11 PM
DI9ITAL
Jan 25, 2003 09:43 AM
CrOmEdOmEcHaMbEr
18
Dec 26, 2002 07:56 PM
