This is bad HUH????? check it out pls
Old Oct 8, 2003 | 09:39 AM
OnebadJdmEg6's Avatar
From: being tracked by FAGS Docking PERCENTAGES, GAYFUKS
Default This is bad HUH????? check it out pls
i just got this block and just to get some more help are the cylinder's bad, what can i do to it now???
if you can see closely there's a line in the middle of each cylinder like its cracked or something what can i do to this to fix it???
I think you could really see on this one
Old Oct 8, 2003 | 09:41 AM
1_bad_EF's Avatar
Default Re: This is bad HUH????? check it out pls (OnebadJdmEg6)
the sleeves are two pieces.
the inside is iron i think the outer is aluminium.
it looks fine to me but The first pic is blurry and that seems to have the best light unfortunately.
Old Oct 8, 2003 | 09:42 AM
kikicamacho's Avatar
WTF? Are you referring to the sleeves?
Default Re: This is bad HUH????? check it out pls (1_bad_EF)
But is it suppose to show the lines/crack in between them??? or is it original????
Old Oct 8, 2003 | 09:45 AM
1_bad_EF's Avatar
it is the two pieces of the sleeve and liner. its fine. I would however get the block decked before putting a head on it. It maybe is warped.
Old Oct 8, 2003 | 09:46 AM
Default Re: This is bad HUH????? check it out pls (kikicamacho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kikicamacho &raquo;</TD></TR><TR><TD CLASS="quote">WTF? Are you referring to the sleeves?</TD></TR></TABLE>
yeah the sleeves/cylinder
Old Oct 8, 2003 | 09:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_bad_EF &raquo;</TD></TR><TR><TD CLASS="quote">it is the two pieces of the sleeve and liner. its fine. I would however get the block decked before putting a head on it. It maybe is warped.</TD></TR></TABLE>
how much would this be??? i have all this pistons and new bearings prepared for my 2nd LS/V project but im just trying to get some inputs from h-t before i do slap anything on
Old Oct 8, 2003 | 11:31 PM
Mochanic's Avatar
the line your refering to, is it vertical, like up and down inside the sleeves?
Or are you refering to the tops of each cylinder where the gasket sits?
(perfectly round on all 4 cylinders?)
Not sure what your trying to show us in the pictures.
Old Oct 9, 2003 | 05:25 AM
advanracing62's Avatar
Default Re: This is bad HUH????? check it out pls (Mochanic)
I'm soooo lost on what you're after here. There are water jackets and there are sleeves. Are you refering to that? Is there an actual vertical crack that runs the length of the sleeve? I think most of us are really lost on this one.
Old Oct 9, 2003 | 06:58 AM
Default Re: This is bad HUH????? check it out pls (advanracing62)
The lines on TOP of the sleeves those circles on top of the sleeves
Old Oct 9, 2003 | 11:01 AM
phatrick2332's Avatar
Just like most everyone said...its where the iron and the aluminum come together in the sleeve. Every honda engine is like that..dont worry about it.
And those pistons are burnt as **** lol
Old Oct 9, 2003 | 11:45 AM
b00sted93Hatch's Avatar
Default Re: (phatrick2332)
If there is separation between the cylinder lining and the actuall aluminium of the block I think that is something to worry about. Has this motor ever overheated?
Old Oct 9, 2003 | 05:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">Just like most everyone said...its where the iron and the aluminum come together in the sleeve. Every honda engine is like that..dont worry about it.
And those pistons are burnt as **** lol</TD></TR></TABLE>
lol n/m those pistons some ctr .25 oversize are going in lol
yeah imma take everybody elses word about it them i'll just go take this block to go get it decked then
Old Oct 9, 2003 | 07:35 PM
Mohudsolo's Avatar
Default Re: (jz)
Have you tried to clean the block? It looks to me like the markoff from the sealing rings around the cylinders on the head gasket. The part of the gasket with the metal fire ring.
Old Oct 10, 2003 | 02:43 AM
jde_07's Avatar
If you are that worried about it I would send the block to aebs and have them resleeve and deck the block and build the motor from there because after they are done with it, it is practically indistructable and good insurance anyways. It will cost a little bit of money but well worth it espically if you plan on running any force induction.
Old Oct 10, 2003 | 08:32 PM
Default Re: This is bad HUH????? check it out pls (jde_07)
okay thanks everybody for the help and replies i really appreciate it im just going to have the block decked before building it
Echelon
Dec 21, 2012 09:41 AM
monster_c
36
Feb 25, 2012 04:27 AM
boostedekhb
Oct 20, 2011 06:18 AM
DC4KiD
Oct 8, 2009 04:41 AM
turbotime
Mar 13, 2006 03:21 PM
