bad CYP Sensor in dizzy required dizzy replacement??
Old Aug 16, 2004 | 08:25 PM
DSRxSALSA's Avatar
Default bad CYP Sensor in dizzy requires dizzy replacement??
throwing a code 9 in my pre obo integera. its a 90 and was woundering if i needed to place the whole dizzy or if i could just replace the CYP sensor in the dizzy? thanx for any help...
Old Aug 16, 2004 | 10:11 PM
DSRxSALSA's Avatar
ttt
Old Aug 29, 2004 | 07:31 PM
sethm's Avatar
Default Re: (92integGS)
bump because I have the same problem
Old Aug 30, 2004 | 09:56 AM
JimBlake's Avatar
Default Re: (sethm)
It's possible the wiring is bad, not the sensor. First rule out dumb stuff like broken/disconnected wiring. I've always heard you have to buy the whole distributor in order to get the sensor.
Old Aug 31, 2004 | 07:16 AM
b18cls1's Avatar
Default Re: bad CYP Sensor in dizzy requires dizzy replacement?? (92integGS)
the internals of the distributers between the sohc dohc vtec and non vtec are the same just find a old obd0 dist and take the guts out of it and put them in yours.
Old Aug 31, 2004 | 07:31 AM
JimBlake's Avatar
Default Re: bad CYP Sensor in dizzy requires dizzy replacement?? (b18cls1)
Take a look in there first... Sometimes the real problem is the distributor shaft bearing is coming apart. That makes metal shavings that get in between the star-wheels & the magnetic sensors. In that case I'm not sure how else you can replace that bearing.
The G2 Racer
Jan 2, 2009 04:42 PM
traybert2003
Feb 8, 2007 09:41 AM
EnSAn
Aug 21, 2006 01:52 AM
sander
Apr 25, 2003 08:17 AM
gvillehnut
Feb 21, 2003 12:00 AM
