Bad Alt. Symptoms???
Old Nov 12, 2002 | 08:57 PM
JalopySiR's Avatar
Default Bad Alt. Symptoms???
O.K. so my setup is a B20 in a ED CRX. I am using my D16 alt. currently. After driving for an hour from GF's house, I stop for gas, leaving car idling. When I get back in, I hear five dim beeps and the tach is sitting on the rest. The clock/int. lights are dimming and the tach is all over the place as I am driving... get to my garage, shut off headlights/acc. everything is fine. Tach goes to normal.... Ideas?
Old Nov 12, 2002 | 09:01 PM
texan's Avatar
Default Re: Bad Alt. Symptoms??? (JalopySiR)
check the system voltage at ~2000 RPM, if it's below 13.5 or so it's likely a bad alt (should be 13.5-14.5 depending on the vehicle). If cranking voltage is low it's the battery. FYI, it's usually the regulator that goes bad in the alt, not the alternator itself.
Old Nov 12, 2002 | 10:49 PM
LB CRX's Avatar
Default Re: Bad Alt. Symptoms??? (texan)
what ever you do, dont take off the battery terminals while the car is running to test it. take the time to do what the guy said above.
Old Nov 13, 2002 | 03:45 AM
PnX-R's Avatar
Here's my cheap guess..
If you tried what the dude said above and it didn't work...
I'd check the alternator belt to see if it's loose..
And you could also check to make sure that the cables/wires going to the alternator aren't loose..
It sounds as if the alternator isn't putting out enough at idle..
Good luck..
Old Nov 13, 2002 | 04:42 AM
Charlie Moua's Avatar
Default Re: Bad Alt. Symptoms??? (PnX-R)
take of off and take it to Napa(free testing)
or drive your car to Autozone (free test)
or drive your car to Sears Automotive(testing can be done on altenator) $25
Old Nov 13, 2002 | 10:15 AM
JalopySiR's Avatar
Default Re: Bad Alt. Symptoms??? (Charlie)
Thanks for the replies. So, it is one or the other?
cjwang2
Mar 26, 2015 08:51 PM
Jdm_JavieR
Jan 26, 2012 01:16 AM
TigerLy
Apr 1, 2009 04:08 PM
Sportyballade
Oct 22, 2006 05:57 PM
hondaless
Jun 9, 2006 08:39 AM
