Backfire? After letting off the throttle and shifts.
Old Oct 28, 2013 | 02:07 PM
Jswike's Avatar
Default Backfire? After letting off the throttle and shifts.
I got my car dyno tuned by a well known professional about a month ago. Since then the car drives sooo much smoother. The only thing is, when I shift, or when I let off the gas to engine break, it will pop, and seem to backfire. The engine doesn't hesitate or anything. The tuner said it may be the fuel cut options in Neptune RTP. I have tried fiddling with almost every option and it does not seem to get rid of it. I just had a friend behind me driving that saw my exhaust when it pops. It blows out black smoke. Any ideas will be appreciated. I actually have an hour long datalog session, if anyone would like to see it. Though, it won't have marks for where the pop occurs.
Old Oct 28, 2013 | 04:23 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Backfire? After letting off the throttle and shifts.
Your tuner is correct... Decel fuel cut settings need to be looked at.
Old Oct 28, 2013 | 05:29 PM
Jswike's Avatar
Are there any suggestions you might have? Right now, parameters are at:
Below load: 249
Below TPS: 1%
Min RPM: 1900
Min Speed: 0
Cut Delay: Id say is about 40% of the bar.
Would it be unsafe to set the min rpm to 1300? If I drop min rpm to 1, would it not idle?
Old Oct 28, 2013 | 09:02 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Do you have any exhaust leaks because I had the same problem when I knocked a flange loose.
Old Oct 29, 2013 | 04:44 AM
Jswike's Avatar
It is possible there is a slight exhaust leak, he had recommended that as a possibility while we took it on a part throttle tuning run. Though only place possible would be where the headers connect to the cat, and the new donut gasket isn't sealing. The reason I considered that option ruled out is because I am using the same exhaust I had for my D15 that was in my hatch. The only difference being a hollow cat. It never popped with the D15, and it didn't pop when I swapped the motor and drove it for 2K miles before I got it tuned. As soon as he tuned it, that was happening. But I will definitely check for exhaust leaks today when I get under the car.
Old Oct 29, 2013 | 07:10 AM
That damn donut flange is what is causing mine. No matter what I do I cant get it to seal up very well. I even added a few washers on the spring side for a little bit more clamping force and it helped but not completely.
Old Oct 29, 2013 | 03:14 PM
I woundnt set the min rpm any lower than about 1600. Make sure your TPS is reading true 0% in the logs when at closed throttle.
Old Oct 29, 2013 | 04:07 PM
Jswike's Avatar
Thanks, the TPS reads -1% when closed on Neptune RTP when datalogging. What does that indicate?
Dillon Crumpler
Acura TL, RL & ZDX
Feb 26, 2018 10:02 PM
NemesisCBR
May 9, 2012 06:21 AM
80884
Jun 9, 2007 09:02 AM
BlueLude84
Feb 13, 2007 10:03 PM
chillly
Apr 15, 2002 07:00 PM
