b20vtec crx check engine light
Old Oct 9, 2008 | 07:08 PM
f20cmx5's Avatar
Default b20vtec crx check engine light
Hi I have a b20vtec crx with an obd1 gsr cylinder head. It runs strong (and rich) with no problems. Vtec hits hard and pulls through 8500 rpm. However after the engine warms up, the check engine light comes on and stays on until the car is turned off. The chassis harness is stock, uncut and out of a 1990 crx si. The engine harness was not wired by myself, but heres what I know about it: It has a chipped p28 ecu with jumpers running from the stock ecu harness to the current ecu ports with the only extra wires running to it being the two for vtec, there are no knock sensor wires, or o2 sensor wires, it has a type r replica intake so a couple of the extra IAB wires required for the gsr are left hanging, it also has an msd ignition system. Does anybody have any idea why the check engine is on? Thanks
Old Oct 9, 2008 | 10:47 PM
rd91sib18c5r's Avatar
Default Re: b20vtec crx check engine light (f20cmx5)
What codes do you have.
Old Oct 11, 2008 | 09:43 AM
f20cmx5's Avatar
Default Re: b20vtec crx check engine light (rd91sib18c5r)
I'm not sure what the codes are. From what I've heard codes can be determined by how the light flashes, however mine comes on and stays soild. Is your 91 red si a rex or a hatch? 13.1 is a good time!
Old Oct 12, 2008 | 01:39 AM
My car is a hatch I have a dry nitrous kit on it.
What obd is your car? Mine is obd2 and I have a wire on my ecu that I ground
and then the check light flashes the code. Good luck
Luke Nutkicker
Mar 22, 2018 06:30 AM
existanzcivicb20
May 1, 2016 08:11 AM
UndergroundTuning
Jan 20, 2009 07:36 PM
f20cmx5
Engine Management and Tuning
Oct 15, 2008 06:30 PM
PhatwhipsJDMkits
Nov 28, 2004 09:31 AM
