b20vtec bad luck day :{
Old Jun 26, 2013 | 01:01 PM
Ruy's Avatar
Ruy
Icon2 b20vtec bad luck day :{
need ur guys advice yesterday my f*cken NAPA timing belt lost like 6 teeth. while driveing hadn't notice until my car shut off while going 60mph i bent my titanium valves. this are my mods p-72 gsr head double spring and retainers b20z2 block high compression pistons about 235 on each piston using ls crank. need ur guys opinions for new valves & timing belt preferably not NAPA especially when they guarantee it for 60.000 miles and dont last 20k
Old Jun 26, 2013 | 06:37 PM
gaby-dr's Avatar
Default Re: b20vtec bad luck day :{
oem timing belt, ferrea valves
Old Jun 26, 2013 | 08:15 PM
Ruy's Avatar
Ruy
ok thanks i was looking at a gates timing belt any reviews?
Old Jul 3, 2013 | 10:17 PM
blackdoom's Avatar
i would use a gates u get what u pay for ive not had problems with them before.
Old Jul 4, 2013 | 10:17 AM
Ruy's Avatar
Ruy
so far ive bought gates racing t247rb timing belt , blox cam seal , honda oem camshaft seals
Old Jul 4, 2013 | 06:58 PM
halfakneegrow's Avatar
Cam gears? What timing belt and water pump combo are you using ?
Old Jul 4, 2013 | 07:00 PM
Orangevirus1's Avatar
Gates timing belt, Or Greddy. never worry again.
Old Jul 4, 2013 | 07:36 PM
slowDB7's Avatar
thats weird, my timing belt from napa was made by gates
Old Jul 5, 2013 | 03:14 AM
DeadlockRiff's Avatar
as far as I remember most Honda oem belts are gates.
I used the Gates blue Kevlar belt on my F22, had no issues with it for tue 55k it was on.
Old Jul 5, 2013 | 08:25 AM
jdmh22eg2's Avatar
same here blue kevlar gates, my only issue is i can not get perfect tention with new oem wp/tentioner/cams/gears. i either have allitle whine or or slop. i run alittle whine rather than slop
Old Jul 5, 2013 | 10:05 AM
wtf_is_jdm's Avatar
Before you just throw parts back in it, be sure to inspect your pistons, guides, and valve seating area for damage. But yes, gates timing belts are decent.
Old Jul 8, 2013 | 03:41 PM
Ruy's Avatar
Ruy
golden eagle cam gears gsr 22 teeth water pump
Old Jul 8, 2013 | 03:49 PM
Ruy's Avatar
Ruy
yup all ready did i vent 2 valves i bought
new ferrea valves
new skunk2 imas
new valve stem seals
what i notice is that my gsr head has after market cams not stock all i see on them is a T engraved on the ends of each cam by where the dizzy goes any one have and idea what kind they are? there not gsr cause i compare them and their much bigger
Old Jul 13, 2013 | 11:37 AM
803motorsports's Avatar
ive always ran a gates kevlar and ive never had an issue with them.
Old Jul 30, 2013 | 04:28 PM
Ruy's Avatar
Ruy
whats the best torque specs for gsr head with arp bolts?
Old Aug 1, 2013 | 06:09 AM
seelback's Avatar
i do three steps on the arp head studs 20-50-80. take a picture of the cams and post them in the drag racing and allmotor section to get a faster response.
Old Aug 1, 2013 | 03:14 PM
Ruy's Avatar
Ruy
ok thanks for your response i just wanted to know other accurate torque specs with my setup because me and my friend just put together a b20vtec using a gsr head with a b20z2 block and we torque it to 22-48-75 and it still leak a little not really noticeable head was resurface flat as a pancake lol. as for the cams ive try to upload them and it wont let me all i know is there not stock gsr cams ive compare them and their much bigger all they have is a T engrave on the end not other marks their solid no rings mark ?
Old Aug 1, 2013 | 03:23 PM
md88hfcrx's Avatar
Sounds like they are buddy club spec 3+ cams. They are marked with a T on the ends
Old Aug 1, 2013 | 10:24 PM
Yup those are the buddy club spec 3+ cams I have a set. Good midrange road race cam
Old Aug 3, 2013 | 08:24 PM
Ruy's Avatar
Ruy
thanks for ur response i coulnt find any info on them all i could find on them is a engrave T in the ends
si90rex
17
Oct 9, 2010 08:08 PM
Gvis420
13
Dec 20, 2009 12:24 PM
00siALLmotor
Acura TL, RL & ZDX
Jan 30, 2005 09:31 PM
Steak84SS
May 26, 2004 04:18 PM
jjaeschke2
Apr 7, 2003 11:05 AM
