B20b swap problems
Old Apr 23, 2013 | 01:19 PM
Vamikeymike's Avatar
Default B20b swap problems
I have a 2000 civic ex took out the y8 that was in originally put in the b20b and it doesn't seem to run right the fuel pump doesn't seem to kick on but it worked before doing the swap I hear the with putting a dual cam in you have to add extra wires is any of this true please any info will help
Old Apr 23, 2013 | 03:04 PM
Default Re: B20b swap problems
I see a lot of people viewed this post some helpfull hints or ideas would be nice
Old Apr 23, 2013 | 05:52 PM
hybridmiklo's Avatar
check the ground on the thermostat housing.
Old Apr 23, 2013 | 06:11 PM
Tyler Dirden's Avatar
I am Jack's...
There may be a possible distributor tooth difference, I think I read about this before. The number of teeth inside the distributor of the B20 and the old motor may not be the same and the computer connot snycronize right. I could be wrong, but I say again; Ithink I remember reading this before. Just a thought. Good luck.
Old Apr 23, 2013 | 06:46 PM
Basik_One's Avatar
How long did it sit before you threw in the b20? Could be your fuel pump, your main relay, could be a ground. Have you tested anything?
Old Apr 24, 2013 | 06:42 AM
kyden's Avatar
what harness are you using? ecu? grounds all secure?
Old Apr 24, 2013 | 07:10 AM
fcm's Avatar
fcm
Old Fart
Check wiring to PGM-FI Main Relay, check/redo thermostat ground(s).
Do a feel/listen test, drop the PGM-FI Main Relay and hold it as you turn on the ign. switch to the run position, [not all the way to start], you should feel/hear two(2) clicks, they are very close together so may feel/sound like one click.
After no more then a few sec. there should be a 3rd click at the same time the CEL should go out.
If the above is not happening, you will need a 12V test light, [not LED type] to do some testing at the PGM-FI Main Relay. 94
eeekthehatch
Nov 14, 2022 09:34 PM
Randomnoob
Aug 29, 2018 12:26 PM
OmenJericho
Aug 15, 2018 05:58 PM
89vwfox
Feb 4, 2009 08:10 AM
thedudefromjerz
Feb 17, 2008 06:33 PM
