B20A5 block + B18A/B head?
Old Aug 12, 2003 | 06:18 PM
Weston's Avatar
Default B20A5 block + B18A/B head?
My Prelude's timing belt snapped and I bent some valves in the head, so it's sounding like ****, smelling like ****, and guzzling gas now. I can't seem to find a B20A5 head for cheap, but with all of the LS/VTEC kids, it's easy to find a cheap B18A/B head... So, what do I need to do to make a B18A/B head fit on a B20A5 block?
I've heard that it can be done, but it's not quite as interchangable as other B-series parts. I need to know the specifics. I don't want any surprises when I try to put it together. Do I have to modify anything to get it to bolt up? Which head gasket would I use? Thanks.
Old Aug 12, 2003 | 07:14 PM
slo2kgsr's Avatar
Default Re: B20A5 block + B18A/B head? (Weston)
well if you can bolt a b16 head on a b20 then and on the b18 then why not a b18b1 head on a b20?
Old Aug 12, 2003 | 08:47 PM
Weston's Avatar
Default Re: B20A5 block + B18A/B head? (tegraLS97)
This is a B20A block in a 3rd gen (88-91) Prelude. It's the same bore as the B18, but has a longer stroke, and possibily a closed deck design. Someone said there were some issues with using a B18A/B head on it, but I need to know the details.
When people say B20, they usually mean a B20B or B20Z out of a CRV, which is just like a B18A/B with a few mm larger bore.
hybrid_vtec
20
Apr 21, 2010 10:22 AM
91teg
Jul 7, 2005 02:33 PM
DAfireman
Nov 25, 2004 10:17 AM
JeremyL
Dec 4, 2002 03:36 PM
LSBeast
10
Sep 17, 2002 06:44 PM
