b20a5
Old Jan 28, 2006 | 12:37 AM
sikgame04's Avatar
Default b20a5
hey im new to this and just wanna kno wat the hell can i do with this motor is it any good, i have it just sittin around and dont kno wat to do with it, its from a 91 prelude si, if anyone can help plz do, much appreciated
Old Jan 28, 2006 | 03:29 AM
methanemotorworks's Avatar
Default Re: b20a5 (sikgame04)
nothing is good on it, unless you plan to put it in another 91 prelude si, the only thing you can use is the crank, put it in a b18a/b and turn it into a b20, other than that...its worthless
Old Jan 28, 2006 | 07:03 AM
sikgame04's Avatar
is it possible, for it to fit into a civic, and if so y is it not any good, its a b-series, i thought they were all good
Old Jan 28, 2006 | 10:55 PM
transpar_nt's Avatar
Default Re: (sikgame04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikgame04 &raquo;</TD></TR><TR><TD CLASS="quote">is it possible, for it to fit into a civic, and if so y is it not any good, its a b-series, i thought they were all good</TD></TR></TABLE>
yeah, you can. The thing with that motor is that almost everything about it is NOT interchangeable with other B series motors. I don't know why, but its the bastard motor that honda should never have built. The specs on it are well below those of a b20b or z, and the cylinder walls are generally considered too thin to boost safely without aftermarket sleeves.
Just as an example about how freakishly obscure the motor is:
My roommate has the same motor in his prelude. We live near Winnipeg and winter is cold here (Canadian cold, not ***** *** American cold ). He bought the car without a block heater but figured it didn't matter cuz he would just get one from the dealership. They don't have them anymore. No worries, a trip to autozone will fix that! They don't have them. Canadian Tire? They don't have them. Everywhere else on earth? They don't have them. Luckily I found out about aftermarket oil pan heaters, but you get the idea. Because there weren't many of those motors made and they're all over 15 years old, Honda has run out of parts for them and only a few manufacturers make a few parts.
Old Jan 29, 2006 | 05:20 AM
StorminMatt's Avatar
It's not possible to drop this motor into a Civic without alot of custo fabrication. It won't drop in. And Hasport doesn't make a mount kit. Bottom line: there are just so many easier and better engine choices that you can make.
Old Jan 29, 2006 | 08:10 AM
sikgame04's Avatar
hey thanks alot u guys, i just donated the car, lmao
Old Jan 29, 2006 | 11:48 AM
Default Re: (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">It's not possible to drop this motor into a Civic without alot of custo fabrication. It won't drop in. And Hasport doesn't make a mount kit. Bottom line: there are just so many easier and better engine choices that you can make.</TD></TR></TABLE>
Wasn't aware of that...
91_Prelude_B20A5
Oct 4, 2007 12:06 PM
valorousguardian
May 9, 2007 08:29 PM
EncoEvolution
22
Oct 4, 2005 10:59 AM
Import_Dumbass
May 8, 2005 07:19 PM
bclue dragon
Mar 31, 2004 01:20 PM
