Accord Brakes
Old Jan 28, 2006 | 09:04 PM
pumafeet10's Avatar
Default Accord Brakes
This has been an ongoing dilemma for me with my car. I am trying to wokr on my rear brakes. 96 ex 4dr allwheel discs and im trying to get one of the rotor retaing screws out of the rotor and well the part where u grip with a phillips head socket is gone and im trying to drill into it and get it out but i can't i breeak off drill bits and i can drill into it. Its like a polished little slug in the rotor. I have use all manner of screw extrators from craftsman i got one screw out but now this second one is just frreakin rediculus!! I can't get a drill bit to bitew in a and strart digging at all and i don't want to have to getra new rear spindle !!!
Old Jan 28, 2006 | 09:16 PM
NJIN BUILDR's Avatar
Default Re: Accord Brakes (pumafeet10)
Get a chisel and knock the head off the screw.I usually grind the head off but I don't know if you have access to one.I don't reuse them.They just hold the rotor in place when the wheel is off.
Glenn
Old Jan 28, 2006 | 10:02 PM
pumafeet10's Avatar
Default Re: Accord Brakes (NJIN BUILDR)
the head of the screw is already gone and i can't get the threaded part out of the rotor!!!
Old Jan 29, 2006 | 05:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumafeet10 &raquo;</TD></TR><TR><TD CLASS="quote">the head of the screw is already gone and i can't get the threaded part out of the rotor!!! </TD></TR></TABLE>
If its not going to fall out than just leave it there.The rotor should come off over whats left of the screw.
Glenn
Old Jan 29, 2006 | 09:36 AM
pumafeet10's Avatar
see thats the thing the threads are still in the rotor so there is no way for it to move at all. Not a very big screw but still its holding tight
Old Jan 29, 2006 | 12:49 PM
I assume the accord is like the civic.The civic uses a small (6mm I think) flat head screw that goes thru the rotor and threads into the hub.In a civic if the head comes off the screw you can just hammer the rotor off the hub.I assume your replacing the rotor.
Glenn
Integra4lyfe069
Apr 11, 2009 06:43 AM
pumafeet10
Jan 29, 2006 01:26 PM
pumafeet10
Aug 31, 2005 12:35 PM
W.O.P.
Apr 28, 2004 03:34 PM
quikrpm'z
Jul 17, 2001 08:04 PM
