b20 vtec timing w/o lower cover
Old Dec 24, 2012 | 11:46 AM
Closenough's Avatar
Default b20 vtec timing w/o lower cover
I changed the water pump on my b20vtec and now I need to set the timing. The cams have not moved since taking it apart but the crankshaft turned while I was removing and installing the timing belt. So I need to get the crank set at tdc but I don't have the lower cover to get it aligned. I set it pretty close by pulling cylinder 1's sparkplug and letting an extension ride the piston until it hit its peak but I was told this was not precise enough. How can I get my crank spot on tdc? Also heard that markings on pulley can't be completely trusted because the pulley can twist some, what I have now:
http://www.flickr.com/photos/69636155@N08/8305209188/
Old Dec 24, 2012 | 12:49 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: b20 vtec timing w/o lower cover
You dont need the cover. Line up the "slash" mark on the crank gear(not the crank pulley) with the pointer on the oil pump.
Old Jan 3, 2013 | 05:02 PM
Closenough's Avatar
Took off pulley and got it all aligned with crank gear, everything went together well after that.
thecorey
Feb 21, 2011 05:12 AM
NSfit
Nov 26, 2006 07:34 PM
virusiidx
Jan 6, 2005 06:38 PM
PM-Performance
Jun 3, 2004 04:51 PM
OBD-One-Kanobe
Nov 1, 2002 09:21 AM
