B20 Vtec / GSR head Not enough oil pressure PLEASE HELP!!! HONDA GODS!!!!!
Old 09-06-2011, 04:44 PM
FSS13foxtrot's Avatar
Default B20 Vtec / GSR head Not enough oil pressure PLEASE HELP!!! HONDA GODS!!!!!
I recently did a B20 Vtec build and i measure 80psi oil pressure from the rear fitting where the head is tapped into. then i only measure 40psi at the oil pressure sensor and when i use a power probe to apply voltago to the solenoid, it only jumps to 40psi. with everything hooked up i ran test light to the connector at the ecu and back probed to see if everything electronically was working at 100% and it is. EVERYTHING electrical is FINE . my problem is oil pressure. I have searched endlessly and found nothing but people having the same problem, then no answer. I also measured from the port at the front of the head (top left) and its the same thing, i got 80PSI at the rear of the head and 40 from the front port. I am losing oil pressure somewhere!!!... the rocker arms lock when i apply air pressure to the oil ports anfd i cannot press down on them. so rocker arms lock, i got 80 at the rear but only 40 at pressure switch. any hel would be appreciated. heres info on the setup....
Car came with LS/V w/ a thrown rod. swapped out the bottom end with b20 block.
OBD1 GSR head
OBD2 B20 block
head tapped already for Vtec. came off running setup
b20 head gasket
Old 09-06-2011, 04:45 PM
Default Re: B20 Vtec / GSR head Not enough oil pressure PLEASE HELP!!! HONDA GODS!!!!!
if u r local n u can help me out of hit me up for some advice then do so... 925-435-6815
Old 09-06-2011, 04:47 PM
andalasmotoring's Avatar
any leakage? what size of braided hose you used?
Old 09-07-2011, 03:40 PM
the steel braided line i used is large enough, i got 80psi going to the head and it worked fine on the previous running setup. i thought of that as well and swapped out lines with a friends and its the same thing. Keep advice coming. thanks
Old 09-24-2011, 09:56 AM
bump...
tobster
03-13-2011 12:32 PM
DOHCarp
04-29-2005 04:19 PM
bruthaboost
10-08-2002 12:57 PM
zdr262
10-23-2001 01:51 PM
Quick Reply: B20 Vtec / GSR head Not enough oil pressure PLEASE HELP!!! HONDA GODS!!!!!
