b20 swap question
Old Jul 8, 2004 | 10:55 AM
eskp1's Avatar
Default b20 swap question
i am planning on putting a b20 into my 96 hatch, i currently have all the parts needed but i was advised from a friend that i need to change my oil pump so the ls ecu will read it other wise it will not start. i havent heard this before so just wonderin if anyone has info on this or if this is necessary or not.... thanks
Old Jul 8, 2004 | 11:32 AM
Tinker219's Avatar
Default Re: b20 swap question (eskp1)
possibly a crank sensor, but the only oil reading the ECU sees is Zero, which is no good(oil light).
Old Jul 8, 2004 | 02:28 PM
eskp1's Avatar
Default Re: b20 swap question (Tinker219)
will the car still run correctly even with the oil light on?
Old Jul 9, 2004 | 05:12 AM
Blaze45's Avatar
Brrraaaap!
I believe hes talkin about your crank angle sensor. The car will start with the oil light on. Make sure that you have your CAS hooked up to the ECU otherwise you'll get a CEL.
Now Im not positive this is what your buddy is talkin about but thats the oil sensor I can think of that would be an issue with that swap.
Good Luck
Blaze
potatointegra01
Jan 20, 2016 08:09 AM
_gurusan_
Feb 24, 2015 02:27 PM
chicows18
Jan 24, 2008 10:33 PM
2SLO
Oct 13, 2003 08:35 AM
eg6RR
Sep 14, 2003 06:09 PM
