b20 in damn check engine light for crank angle sensor
yeah b20 running fine but i feel the check engine light is holding something bac and plus i hate it. how do i get rid of the crank angle check engine light.
Re: b20 in damn check engine light for crank angle sensor (CTRKID)
More info is needed what car is this motor in.. what year block? is it JDM/USDM...what harness are u running.. what ECU are u using...
oh yeah. its a 98 jdm b20b in a 97 civic hatch running a ls ecu with the stock wiring harness w/ some extension done. im think i should use a ls water pump or oil pump so i can get the sensor and try to find a plug to fit im just lost at the moment to many problems?
Re: (CTRKID)
yeah either replace the oil pump with a OBD-2 US oil pump and place the CFK sensor on it and plug it in.. from there you won't run any cides... or you can run an adapater harness OBD-2==>OBD-1 and run a OBD-1 LS ecu and u won't get the code
PushinRedline
11-05-2007 09:06 AM
