B20 stroker kits
Old Feb 9, 2004 | 10:17 AM
Macine's Avatar
Default B20 stroker kits
Has anyone heard anything about Eagle's stroker kit they have for the CRV block? I believe it uses a 95mm stroke to make it a 2.2l. I am trying to figure out what is the best way to go?? Suggestions please.
Old Feb 9, 2004 | 10:29 AM
b18bturbo's Avatar
Default Re: B20 stroker kits (Dev)
you could use the b20a crank 95mm stroke with a 85mm bore for a nice setup i just dont like the rod stroke ratios of those motors. I would actually destroke and go larger bore
Old Feb 9, 2004 | 04:21 PM
Macine's Avatar
Default Re: B20 stroker kits (b18bturbo)
I agree but the bore is limited to 85-87mm and over 85mm cylinder warpage may be a problem. For the quarter mile the increased torque would greatly help. Rod Ratio plays a much larger roll in endurance racing or when the motor size is restricted. I do agree a longer rod is better but unless I invest in a deck plate I think this would be the best?? What do you think?
Old Feb 9, 2004 | 07:11 PM
7thGear's Avatar
in my opinion once you start adding deckplates on to engines your defeating the whole purpose of staying in your engine class, imo deckplates are almost like cheating...
you have a 2.0 liter, do the best you can with it, it was never built as a race engine, so why try to make it into one.
( and even if you were making it into a race engine, i would push it to the limit in its current stage, and only go for a stroker kit when more displacement is the ONLY way out)
egycasper16
38
Mar 21, 2019 05:17 AM
oldskooldan
Sep 6, 2011 04:07 PM
Black R
Nov 26, 2003 10:31 PM
davken1102
Oct 10, 2003 08:23 PM
infamousALLMTR
16
Jun 20, 2003 05:35 AM
