b20 help
Old Jun 14, 2009 | 09:18 AM
feriotypeR's Avatar
Default b20 help
what wire harness can i use? can use my d16y8 harness? what ecu do i use also?
Old Jun 15, 2009 | 02:54 PM
ltrkstr2k's Avatar
Default Re: b20 help
yes you can use your y8 harness the ecu depends on what year the car and engine are. if its obd2a get a stock crv ecu or a 96-98 ls ecu. if its obd2b (99-00) get a 99-00 ecu. or you can change some plugs get a obd2a - obd1 conversion harness and run a ls or chipped obd1 ecu
Old Jun 15, 2009 | 05:03 PM
feriotypeR's Avatar
its a 99 civic and a jdm b20b 97. so i can still use my y8 harness and a ls ecu?
Old Jun 15, 2009 | 05:16 PM
ltrkstr2k's Avatar
yep you should be able to run a 99 ls ecu or a 99 crv ecu
Old Jun 15, 2009 | 05:48 PM
speedworks's Avatar
always use the wiring harness off of the engine out of the car you are working on. never switch harnesses, just add, lengthen, or modify the wires as needed
Old Jun 15, 2009 | 06:40 PM
feriotypeR's Avatar
thanks guys
Old Jun 16, 2009 | 12:20 AM
civic-one's Avatar
If you use an obd2 ls ecu you will throw out a CEL. Use and obd1 ecu and youll be fine.
jdmjunior1991
Mar 11, 2014 05:19 AM
eric p
Feb 7, 2009 04:25 PM
faxshatch
Mar 18, 2008 05:08 PM
93dagsr
Jul 31, 2007 01:52 PM
30stones
Aug 28, 2004 08:08 AM
