B20 eg wont idle
Old Apr 2, 2009 | 05:57 PM
EJ-1's Avatar
Default B20 eg wont idle
hey i just did a swap in my 94 dx, i swapped a 97 b20 non vtec in it, and the car starts and drive fine but it wont stay idle
ive messed with the idle screw
cleaned out the iavc
swapped out the tps and mapsensor
ive also check for vacuum leak, cant find any
im not throwing any check engine light
it would idle at about 100, an just wanna die out, while drivin an at ay stop the car would just die
Old Apr 2, 2009 | 08:43 PM
RC000E's Avatar
Default Re: B20 eg wont idle
What ecu you running it on?
Old Apr 2, 2009 | 08:54 PM
jdm inc's Avatar
same thing happen to my buddys car....found out that the ecu got burnt up and was no longer good..
The car wouldnt ide and wouldnt drive over 1500 rpm... so that might b your problem try another ecu...
Old Apr 6, 2009 | 08:49 PM
EJ-1's Avatar
im using a p75, my ecu cant be bad because i tried two diff ecu, and i can drive fine just that my idle is really low every time i come to a complete stop it just dies
Old Apr 7, 2009 | 06:22 PM
EJ-1's Avatar
can it be the iavc? the cleaning must of not helped it? bump!
ArchEnemyEJ1
26
Mar 23, 2016 08:28 PM
hondacurious
Engine Management and Tuning
Jun 28, 2011 01:39 PM
candy eg
Aug 17, 2006 02:22 PM
danslerugueux
18
May 15, 2004 01:12 PM
S2KP
Dec 25, 2003 05:58 PM
