B18c5 JDM motor info
Old Aug 12, 2002 | 11:45 AM
kuelerz's Avatar
Default B18c5 JDM motor info
i am going to be putting a b18c type r in my 98 civic and i know how to do everything but i had a couple questions about the A/C. i want to use my a/c after the install but will i need to change any of the brackets. i have gotten a 100 different answers but the most logical seems to be that i will need an a/c bracket off of a 99 si, is this true?
Old Aug 12, 2002 | 12:28 PM
VTECorona's Avatar
Default Re: B18c5 JDM motor info (kuelerz)
I don't see why it would be narrowed down just to a '99 si'. If anything it should be off of a b16\b18C. .02
Old Aug 14, 2002 | 12:49 AM
carcala's Avatar
i would try using the 99-00 civic si one. Or if u can get a bracket from any integra with the compressor for less hassle.
Old Aug 14, 2002 | 12:56 AM
kinesistech's Avatar
Default Re: B18c5 JDM motor info (carcala)
Every one is dumb. I would use a Del Sol bracket or new SI only. Integra brackets are for integ a/c compressors which are different.
Old Aug 14, 2002 | 02:08 AM
B18C-EJ1
Guest
Posts: n/a
Yes, this is correct. You can also use the 94-97 delSol VTEC (only) bracket.
Like KinesisTech (Ryan) mentioned, the teggy brackets are only for Teggy AC compressors.
They are not interchangable. The AC lines mount differently from the Civic lines.
4BangahEK9
Jul 2, 2007 05:37 PM
jadsi420
Sep 12, 2005 03:10 AM
jdm jedi
Sep 14, 2003 03:21 PM
jdm jedi
Sep 14, 2003 02:28 PM
GapxGuy
11
Feb 19, 2003 02:08 PM
