b18c5 cooling help!!!
Old Aug 12, 2003 | 11:48 PM
WCI's Avatar
WCI
Default b18c5 cooling help!!!
I have a b18c5 block with a b16 head in a 97 hatch. was getting hot before with the stock radiator so I put in on from an early accord that took up the hole front. thought it was working but is having the same problem as before... sits at normal running temp(right under half) then will go up to alittle over half. For no apparent reason it will drop suddenly back down to operating temp again. It started to heat up tonight so I pulled over and the top coolant line was hot (ofcoarse) and the lower was surprisingly cool. dunno am getting real frustrated- thanks
Old Aug 13, 2003 | 12:02 AM
mmuller's Avatar
Mad Scientist
Default Re: b18c5 cooling help!!! (WCI)
check thermostat
Old Aug 13, 2003 | 01:06 PM
WCI's Avatar
WCI
Default Re: b18c5 cooling help!!! (mmuller)
yea it was totally the wrong one got a new one-thanks
Old Aug 13, 2003 | 02:04 PM
allwheelerman's Avatar
azack_J
Nov 6, 2015 04:38 PM
JdmJah
Jul 14, 2010 09:43 AM
505hightek
Oct 9, 2008 01:14 PM
ranger714
Aug 14, 2005 09:33 AM
abaaj
Feb 22, 2005 04:54 PM
