b18c1 loosing oil?
Old Nov 20, 2001 | 09:15 PM
swarsing's Avatar
Default b18c1 loosing oil?
no smoke from the exhaust,no leaks to be found.i'm not sure how many miles on the motor can only take the shop that did the swap word (i was told around 67k) what should i check for next?also does anyone know the code for a gsr tranny (mine has s80)any downfalls of the s80 tranny?
Old Nov 20, 2001 | 10:53 PM
nugget8000's Avatar
New User
Default Re: b18c1 loosing oil? (swarsing)
About the loosing oil, either it is leaking it or burning it, one or the other. If it is very slow consumption then you could be burnung it and not really notice anything out of the exhaust pipe. Our engines do tend to consume small amounts of oil when they spend a lot of time at WOT. Places to check for leaks would be the cam seals, both under the timing belt cover and especially by the VTEC solenoid (both quite slow leaks). Also chech that there is absolutely no oil or traces of wet oil around the drain plug (can be a fast or slow leak). You might also want to chech the PCV valve to make sure it is not clogged. If that gets clogged you can build up excessive oil pressure which would cause blowby which would be bad for your rings as well as burning more oil than normal. Other than that if it is not a lot of oil I wouldn't really worry about it. A normal amount of oil would be around 1/4-1/2 a quart between oil changes, or every 3000 miles. HTH.
Old Nov 21, 2001 | 09:51 AM
swarsing's Avatar
Default Re: b18c1 loosing oil? (nugget8000)
thanks for the input
Old Nov 21, 2001 | 12:31 PM
Crossett's Avatar
The harder you drive the more oil you burn.
Old Nov 23, 2001 | 09:12 AM
swarsing's Avatar
Default Re: b18c1 loosing oil? (Crossett)
if my rings weren't sealing properly i would have oil on my plugs right?i pulled them yesterday and nothing(although i'm running lean)any other things that are easy to check,where is the pcv valve located on the b18c1?would a clogged cat have anything to do with loosing or using oil
Old Nov 23, 2001 | 09:22 AM
rtype11's Avatar
if the cat was clogged or PCV that would cause lots of blowbye, if you are not venting your crankcase properly the bottom rings on your pistons wont seal, if you put a filter on your valve cover take it off and replace the hose to intake.if the cats clogged it may fill with oil and thats why it doesnt burn. if the motor was beat on you may want to have guides examined but dont do anything untill you take care of a compression test and even a leakdown test.
Old Nov 23, 2001 | 09:48 AM
swarsing's Avatar
Default Re: b18c1 loosing oil? (rtype11)
i pulled the pcv valve and some oil
scubacamper
Mar 24, 2016 10:24 AM
davey5300
Aug 16, 2009 07:29 PM
gooberwolf
Dec 24, 2008 08:43 AM
DAintegraGSR
Apr 28, 2005 08:22 PM
