B18C1 intake q's?
Old Sep 25, 2003 | 02:26 PM
Big Bang's Avatar
Default B18C1 intake q's?
Ok what should i do with these? Take out the butterflies or wire them up to my PR3 to do what they are supposed to?
Mark
Old Sep 25, 2003 | 02:33 PM
mmuller's Avatar
Mad Scientist
Default Re: B18C1 intake q's? (The Converted)
you cant control secondary butterflies with a pr3 ecu.
leave them open, change ecu's or change manifold
Old Sep 25, 2003 | 02:49 PM
Big Bang's Avatar
Default Re: B18C1 intake q's? (mmuller)
I was pretty sure that i saw a pin out diagram for a PR3 ecu with the output for the secondaries. Mine is chipped if that makes any difference.
Old Sep 25, 2003 | 03:22 PM
mmuller's Avatar
Mad Scientist
pr3= no secondaries
doesnt matter if its chipped
Old Sep 25, 2003 | 04:34 PM
Big Bang's Avatar
Ok so in that case would it be of any benifit (daily driver) to hook up the secondaries to an rpm module, or should i just tear out the butterflies?
Old Sep 25, 2003 | 08:00 PM
Mochanic's Avatar
just simply unbolt the butterfly section and get some shorter bolts... Voila your done!
Old Sep 26, 2003 | 12:30 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: B18C1 intake q's? (Mochanic)
or disconect the vacum line to the butterfly actuator
Old Sep 26, 2003 | 01:05 AM
Mochanic's Avatar
Default Re: B18C1 intake q's? (92 civic VX B18c)
yeah your right 92 civic VX B18c, vacuum will close it and create a longer path for the air to travel which increases bottom end TQ... take it away and both side open and you increase volume and and shorten the runner which creates HP, but when you take the whole thing out, it shortens both runners and makes it more like a conventional intake. Also if you notice the picture the runners are different size diameters, which will increase the air speed on the smaller side thus creating more TQ as well.
You could hook up an MSD RPM activation switch to changeover at around VTEC like the factory ECU does... it would be extrremely easy to do!
Your choice.
Modified by Mochanic at 4:49 AM 9/26/2003
Old Sep 26, 2003 | 01:09 AM
HT Black Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mochanic &raquo;</TD></TR><TR><TD CLASS="quote">yea and kill your top end performance!</TD></TR></TABLE>
Why if you disconnect the vacum line the default to open....
no vacum line hook up and they are open
Old Sep 26, 2003 | 03:02 PM
Big Bang's Avatar
no vac line, they are open, loose 10 ft/lbs of tq
Old Sep 26, 2003 | 06:23 PM
mmuller's Avatar
Mad Scientist
yes, if you leave them open you'll lose a gang of top end...
just wire them to a rpm switch
Old Sep 26, 2003 | 09:02 PM
HT Black Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">yes, if you leave them open you'll lose a gang of top end...
just wire them to a rpm switch</TD></TR></TABLE> Why do you keep saying you'll loose top end if you leave then open? They open @ high rpms, what you loose is some low end
Old Sep 26, 2003 | 09:47 PM
Mochanic's Avatar
correct.
GSR615
Engine Management and Tuning
May 20, 2010 04:22 AM
Roger
34
Sep 25, 2003 12:29 AM
oneslodx
Sep 9, 2003 05:55 PM
43MA
Nov 27, 2002 08:44 PM
dabomb
Sep 19, 2002 11:01 AM
