B18C1 GSR VTEC PROBLEM
Old Aug 7, 2016 | 10:27 AM
Daniel_Bseries's Avatar
Default B18C1 GSR VTEC PROBLEM
Hi , i have a problem with my civic 94 with GSR swap the problem is passing 5,800rpm don't pop vtec sound any sound and a few weeks later showed Check engine light and after that always is with Check engine light , what is the problem ? maybe Ecu error with solenid ? or something ? Thank you
Old Aug 7, 2016 | 12:36 PM
holmesnmanny's Avatar
Default Re: B18C1 GSR VTEC PROBLEM
pull the codes
Old Aug 10, 2016 | 02:27 AM
HondaPartsHero's Avatar
Technical Hero
Yes pull the codes. Also what ECU do you have? Are you saying it doesn't pass 5800 RPMs?
Old Aug 16, 2016 | 11:24 AM
I guess it's p72 96-00 i guess that is the ecu but passing 5,800rpm doesn't pop vtec sound and I suppose it is working and i read some post that said when Check Engine is ON the vtec doesn't work I didn't put scanner yet Thanks too answer
Old Aug 16, 2016 | 12:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
5,800 is not the VTEC changeover point. That's when the secondary intake runners open, and unless you have a 94-01 GSR ECU, it's not going to open the intake runners.
Old Aug 16, 2016 | 01:11 PM
fcm's Avatar
fcm
Old Fart
You "guess" it is a p72, maybe should pull the ECU and confirm what it is.
What year is the GS-R engine?
Is it a USDM or JDM engine? 94
Old Aug 19, 2016 | 01:18 AM
Originally Posted by holmesnmanny
pull the codes
error2k
Mar 3, 2010 12:47 PM
mvp97gsr
Feb 19, 2009 09:14 AM
pheardone
Jan 3, 2009 05:56 PM
crazihobo
Dec 4, 2008 07:41 PM
wiber1
Mar 24, 2002 04:21 PM
