b18c idles funny when i stop
Old Jul 7, 2004 | 08:24 PM
dippin16z's Avatar
Default b18c idles funny when i stop
i have just installed a larger sized throttle body (70mm rpm) on my gsr and it idled funny after i port matched it... i put the manifold in and everything and the car turned on then i drove it and when i hit a stop light or stopped completely my rpm's would almost drop to 0 like if it was going to stall but then it regains its composure and idles like 800 rpm after and it stays steady then i go again and the process repeats. i will reseal the vacuum lines and see if those were missing but i just had to post this to see... this shop said it might need a valve adjustment because my head was sounding kinda loud... what would u guys suggest me on doing if it was not my vacuum lines? should i just go ahead and try to get my valves readjusted? or would it be the settings on my throttle body...
also i tried looking for the thing to adjust the throttle on the throttle body and i couldnt find it on the RPM 70mm throttle bodies... i found a alan wrench kinda thing near the tps sensor but not sure if that could be it...and my 4mm was to small and my 5mm was to big perhaps they have a separate key? thanks for the help... anyone...
Old Jul 7, 2004 | 11:18 PM
92bubblesi's Avatar
Default Re: b18c idles funny when i stop (littlebeastEK)
Did you try resetting the ECU after installing the throttle body. When I do stuff to my car and it starts idling like **** resetting the ecu usally does the trick. Did you reuse the throttle body gasket? It could be leaking.
Old Jul 8, 2004 | 05:18 AM
EE_Chris's Avatar
Default Re: b18c idles funny when i stop (92bubblesi)
Using the stock components (stock throttle body without your port matching) there exists a certain flow velocity in the intake. When you open things up with the parts that you did, you're killing this velocity - well, perhaps not killing it, but slowing it down to the point where not all the air that the ECU once thought was going into the manifold/chambers is still going in.
Is there an idle air bypass screw on this throttle body or just a throttle plate stop screw?
Raising the idle will probably help - but go to far in raising it and then you'll get the hunting idle.
Do you have a lot of mods to take advantage of this throttle body?
Old Jul 8, 2004 | 11:55 AM
dippin16z's Avatar
Default Re: b18c idles funny when i stop (EE_Chris)
well i did pull out the back up fuse out of the box for like a minute then started it again... ill try the ecu though today... and reinstalled a better intake... cuz my adapter was to small and now the idle is not as bad ... i took it around the block and it didnt almost die on me... and
i didnt reuse the old gasket. i had to cut it myself when i bought a new one because when i port matched the manifold the gasket was to small...and also i dotn think there is a screw for the throttle body i have i cannot find it...
jhoffy22
Oct 17, 2013 03:49 PM
jksmith
Feb 19, 2009 09:39 AM
hkrichard
Apr 27, 2008 06:03 PM
EF9-G'zer
12
Aug 6, 2004 08:20 PM
ultra efro
Feb 22, 2004 05:53 AM
