B18c cam gears alignment.
Old Feb 1, 2014 | 12:08 PM
Jmx305's Avatar
Default B18c cam gears alignment.
So I replace my cam gear oil seal and when I'm about to put back my timing belt I can't get my intake cam "up" mark straight up. My exhaust mark is dead on. Any suggestion on how to fix it? My oil pump mark and crank mark all line up
Old Feb 1, 2014 | 07:10 PM
F22Master's Avatar
Default Re: B18c cam gears alignment.
turn it clockwise.
Old Feb 3, 2014 | 06:59 AM
Jmx305's Avatar
Clock wise? The motor turns counter clockwise. The alignment marks on the side are off my just a little. Maybe by putting the belt and tighting everything everything will line up?
Old Feb 6, 2014 | 02:29 AM
$MIKE$'s Avatar
There is a tiny hole in the cams and in the cam cover so you can pin them at tdc,
I stuck an Allen wrench in both of mine during install this ensures that they stay tdc while fitting to get the t-belt on.
It's a hole on top of the cam cAp/cover closest to the cam gears.
Old Feb 10, 2014 | 08:57 AM
Jmx305's Avatar
I was able to put everything back together and line everything up on the dot, and now the car is up and running. I didn't know about the hole, it would have helped a lot if I had known sooner well thanks anyways now I know for next time.
KURUPTinc
Apr 17, 2008 09:31 PM
donut.
Mar 19, 2007 08:19 PM
integlstrike1
Aug 13, 2006 07:45 AM
rbanke
May 13, 2006 01:17 PM
sph33r
Feb 19, 2006 09:53 AM
