B18A block help!!!!!!!!!! broken!!!!!!!!
Old Nov 1, 2004 | 04:39 PM
Death_to_Thieves's Avatar
Default B18A block help!!!!!!!!!! broken!!!!!!!!
hey whats up guys I have a b18a block and I noticed that one of the water pump bolts is broken off inside the block. how do I fix this?? is my block shot or can this be tapped out and fitted with another size bolt? what can I do? Im kinda nervous, I was going to be sleeving this block to 84mm for my new setup. Any help is always appreciated. Thanks
Old Nov 1, 2004 | 04:47 PM
drdisco69's Avatar
Default Re: B18A block help!!!!!!!!!! broken!!!!!!!! (8000KReV)
Either drill it and get a broken screw extractor, or let the machine shop do it. Not really a big deal.
Old Nov 1, 2004 | 04:55 PM
Default Re: B18A block help!!!!!!!!!! broken!!!!!!!! (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Either drill it and get a broken screw extractor, or let the machine shop do it. Not really a big deal.</TD></TR></TABLE>
so nothing really to worry about??
Old Nov 1, 2004 | 05:00 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8000KReV &raquo;</TD></TR><TR><TD CLASS="quote">
so nothing really to worry about??</TD></TR></TABLE>
Just have the machine shop extract it when you get it sleeved. We broke a water pump bolt off in a b18c1 block and we attempted to "drill and extract" it and the extractor broke inside the bolt .
Phil
Old Nov 1, 2004 | 05:03 PM
drdisco69's Avatar
Default Re: B18A block help!!!!!!!!!! broken!!!!!!!! (hondaguyef)
Yeah, I've had mixed success with extractors. I mean, the bolt broke off in there because it's stuck, so...
Old Nov 1, 2004 | 05:21 PM
captainjdog's Avatar
I did same thing, Just drilled it out and put a big bolt in it. 20k miles later still holdin. had to bore hole out in waterpump as well. But that was the ghetto way of doing it.
Old Nov 1, 2004 | 05:30 PM
Default Re: B18A block help!!!!!!!!!! broken!!!!!!!! (captainjdog)
so just stick with bringing it in to the machine shop huh? As long as this is not seen as a major issue, I guess Im ok then. Thanks everyone
Linus_E
Mar 23, 2005 04:52 AM
d16rice
15
Feb 21, 2005 01:05 PM
incognitoracerr
Aug 18, 2003 05:31 PM
turbodGSR
Apr 27, 2003 09:00 AM
