B18 Problems Need Some Help
Old Feb 8, 2011 | 05:03 PM
Red 93 EG Hatch's Avatar
Icon6 B18 Problems Need Some Help
I have a B18A1 swap in my 93 Civic EG Hatch the car will start and run fine when it has been sitting and the motor is not warm. But when I start the car and let it run for a little bit or drive it then turn the key off the car will not start again. I just got done replacing the Ignition Control Module because some people have told me that could be my problem. Still wont start after the car is warm the engine will just crank. The fuel pump kicks on and primes so I dont think it is the main relay. Could use some advice on what the problem might be if anyone can help me.
Old Feb 8, 2011 | 05:30 PM
wtf_is_jdm's Avatar
Default Re: B18 Problems Need Some Help
Are you running a tune?
Old Feb 8, 2011 | 05:57 PM
I have a chipped ECU with a base map that a guy put on the chip.
Old Feb 8, 2011 | 06:02 PM
I think I am actually running to much fuel because when I get up in the higher RPMs it will start to pop like a 2 step till I shift gears. The spark plugs are also a black color when I pull a spark plug after trying to get the car to start also when I look into the cylinder the top of the pistons is all wet with fuel.
Old Feb 8, 2011 | 06:45 PM
fcm's Avatar
fcm
Old Fart
Do you have spark, is it a "strong" spark?
Are your injectors pulsing, could they be "sticking open"? 94
Old Feb 9, 2011 | 04:37 AM
From what I have checked out I have spark I have an MSD ignition with a Blaster SS coil. If my injectors are sticking open how can I tell or know.
Old Feb 9, 2011 | 05:40 AM
fcm's Avatar
fcm
Old Fart
Is it a strong spark?
If the black "stuff" on plugs looks soft and sooty it could mean over rich air/fuel mix or a weak spark, or is it a wet black?
You can use a noid light... http://www.noidlight.com/how-to-use-a-noid-light/ a multimeter or low current test light to check the injectors. 94
Old Feb 9, 2011 | 08:12 AM
Its more of a wet black not real sooty.
Old Feb 10, 2011 | 01:39 PM
frankenghia's Avatar
Do you actually hear the main relay click? I had the same problem on a 94 hatch. My fuel pump would prime and everything but the relay never clicked. I took it to Hondoctors and they replaced the relay and I haven't had any problems since. Just a thought......
Old Feb 10, 2011 | 03:19 PM
I cant say that I have heard the main relay click just the pump kick on then off is about all I hear but I guess I will just replace that an see what happens I guess I am running out of options really. Next step is to take it to someone that knows what the heck they are doing.
Old Feb 10, 2011 | 04:11 PM
fcm's Avatar
fcm
Old Fart
Replacing parts without knowing what the problem is is an expensive way to troubleshoot a problem.
If you are getting fuel into the cylinders, it is a good bet the PGM-FI Main Relay is working.
If you can not hear the clicks of the relay, you can feel them, hold the PGM-FI Main Relay in your hand, turn on the ign., you will hear/feel two (2) "clicks", it may feel like one click as they are very close together, first click is the injector relay, the second click is the fuel pump relay, at the same time you will hear the fuel pump turn on and the CEL will turn on, after a few sec. you will hear/feel the 3rd click, [fuel pump relay turning off] fuel pump will stop and the CEL will go out.
Leave ign. on and check for power at the injectors, [wire that is the same color on all injectors].
If all the above is happening there is nothing wrong with the PGM-FI Main Relay.
Again, how good is the spark??? 94
Old Feb 10, 2011 | 04:27 PM
I just checked the main relay and from what I can hear it is clicking so I guess that is working. The spark is a pretty stong spark I just checked that also. So I am lost with what is wrong with it haha
Old Feb 10, 2011 | 06:23 PM
night's Avatar
coolant temp sensor. do it again, but before you restart warmed up, unplug the sensor.
Old Feb 11, 2011 | 02:35 PM
Ok I will try that and see what happens when I unplug the coolant sensor hopefully that works
Old Feb 12, 2011 | 08:05 PM
QUICK8CIVIC's Avatar
Take it to your tuner.
Old Feb 12, 2011 | 08:30 PM
I need to take it to someone thing is I dont know of any tuner around my area. But its not the main relay I also tried unpluging the coolant temp sensor an that didnt help either so I guess my only option is to find someone that can tune it or knows what the heck they are doing
Old Feb 12, 2011 | 08:43 PM
night's Avatar
yep, you have expended what we can guess at over the net
Old Feb 13, 2011 | 03:23 AM
That could be a bug on CRome.
Old Feb 13, 2011 | 03:35 AM
*JDM*Ej8*'s Avatar
I just got over this same problem about 15 mins ago loose ground wire and batt starter connection. was too loose
Old Feb 13, 2011 | 08:39 AM
Well I will deffinately take any advice I can get so I will go an check all my grounds and the starter connection
Old Feb 16, 2011 | 03:00 PM
Thanks alot for all your help everyone I got the car running it starts everytime now love it. If you were wondering what it was it was the coolant temp sensor so everyone that told me that thanks for all the helpfull advice.
Old Feb 16, 2011 | 03:08 PM
Oh the only thing I have a question on now is when I drove it to my buddys house to put the rest of the exhaust on it seemed like it was driving wierd like something was holding the car back seemed kinda slugish. It would rev up but just seemed like it didvt want to go very good any advice on what might be causeing that.
Old Feb 18, 2011 | 04:24 AM
You need a tuner now..
Old Feb 18, 2011 | 08:40 AM
night's Avatar
if it was a stock motor with a stock ecu i'd say timing, but otherwise.. tune
Old Feb 18, 2011 | 02:51 PM
Ok thanks guys I figured thats what the problem was but wanted to get an opinion from some of you guys thanks a ton for eveyones help.
cre-ej1<3
Jan 14, 2016 11:12 PM
bLaCk-SoHc
Mar 14, 2007 07:53 PM
boostedpleasure
13
Oct 12, 2006 09:10 AM
Performance Freaks EH
Apr 3, 2006 03:53 PM
