B18 non vtec distributor issues
I just dropped a b18 non vtec swap and had to get a new obd 1 dizzy using a jumper from obd 2 to obd1. The car cranks but does not turn over I checked the firing order and its still doing the same thing not sure what else could be the issue .
Have you checked compression?
Do you have a good spark, use HEI spark tester to check.
What is the fuel pressure. is fuel reaching the cylinders, [are injectors working]?
More info on the car the swap went into and what B18, there are a few? 94
UltimX
Jul 4, 2014 07:30 PM
JDM_HNIC
24
Jul 13, 2011 08:47 AM
Max500
Mar 17, 2011 08:05 PM
sitinthehall
Sep 26, 2005 08:59 PM
