B17a vs B18C1
Old Nov 17, 2009 | 06:41 PM
N.Balauro's Avatar
Default B17a vs B18C1
Ok i potentially have an opportunity to grab up an b17a with a 2000 itr tranny. My question is what are the differences between the 2 engines besides rods and crank? Besides that they appear to be identical.. Can anyone fill me in? I would liek to grab this ddeal and just swap in a c1 crankand rods for the displacement.
Head Flow, Cams, Block Casting differences, etc...
Old Nov 17, 2009 | 07:15 PM
88Hatchy's Avatar
Default Re: B17a vs B18C1
The B17A is basically a stroked B16, it also has a B16 (PR3) head. A B18C1 has a taller deck height, a different head casting (P72), and much more potential. There has been a lot of debate as to which head flows better. You cannot use a B18C crank and rods in a B17/B16 block.
Old Nov 17, 2009 | 07:26 PM
N.Balauro's Avatar
I see thanks for your response... I didnt think about it that way i was basically thinking a destroked b18. That sucks i really wanted to scoop this deal up for the tranny but idk if its worth it IM kinda opting for a b18 platform...
Old Nov 17, 2009 | 07:43 PM
MSchu's Avatar
My Name is Nobody
why wouldn't you still get the deal? I think you are confused... this isn't a b18a, it's a b18c5... completely different beast. The Type R head and the pr3 b16/17 heads are very closely related... the b18c1 head is different, that's a second gen GSR head.
I re read your post, you want to add c1 internals into a 17a block? not gonna happen, there's 10mm deck height difference between the two engines, though you could add the 17a crank to the c1 block for a turbo option
ramtyper19
Mar 31, 2005 07:33 AM
RAS Motorsports
Oct 19, 2004 02:05 PM
nightryder21
May 7, 2003 11:15 PM
Kwuaymaikrup
Mar 2, 2003 07:18 AM
My Documents
Jul 19, 2002 12:24 PM
