B16A2 (99 Si) Compression Test Numbers
Old Jul 4, 2006 | 08:28 AM
gottabfast's Avatar
Default B16A2 (99 Si) Compression Test Numbers
My buddy just bought a 99 Si with a Jackson Racing Supercharger Kit. We went to refresh everything this weekend because the car had been sitting forever. We compression tested the motor and the came up with (1-->4): 148-150-148-162. What should the compression test results be? They're all within 90% of each other, which is good, but I'm not familiar with what range they should be in for that engine.
Thanks!
Old Jul 4, 2006 | 11:21 AM
SuzukaBlueAP2's Avatar
Default Re: B16A2 (99 Si) Compression Test Numbers (gottabfast)
Someone can correct me if I am wrong, but I would think that engine should be seeing atleast 160 in all cylinders if it were healthy. I know I've seen compression results upwards of 185-200.
How many miles are on that engine? How long has it been boosted? How much boost?
Old Jul 4, 2006 | 01:57 PM
gottabfast's Avatar
just under 48K miles, but I have a feeling it was a guinea pig for a shop to test their e-manage tuning skills. It runs horribly rich, so it was tuned seemingly very conservatively. I think the kit pushes 7 psi at the most.
Those numbers sounded really low to me too, I just wanted to confirm it. I'm usually a nissan guy...
Old Jul 5, 2006 | 01:18 PM
gottabfast's Avatar
Just for future reference, I talked to a dealership today and they said anywhere from 150 to 180 is ok with a 10% drop between cylinders. It's completely out of spec if the drop is 25% on any cylinders.
Type 56
Engine Machining & Assembly
Aug 13, 2017 06:34 PM
cvclover
Feb 23, 2007 02:28 PM
Nate B
Jun 21, 2003 03:45 PM
Slick GS-R
Apr 23, 2002 04:33 PM
