b16a1 w/ OBD1 distributor
Old Jun 15, 2003 | 01:24 AM
n1_ek's Avatar
* B A N N E D *
Default b16a1 w/ OBD1 distributor
i was wondering if a 94-95 integra LS distributor work on my b16a1? also since i have a 92 civic si do i have to change the injectors as well on the b16a1 to obd1 injectors?
Old Jun 15, 2003 | 07:56 AM
altoid's Avatar
Default Re: b16a1 w/ OBD1 distributor (ryan819)
wasn't the b16a1 from the del sol? if so then its already made for obd1 if not then i can't help you there
Old Jun 15, 2003 | 10:21 AM
mmuller's Avatar
Mad Scientist
Default Re: b16a1 w/ OBD1 distributor (altoid)
you can use a ls dist., but you have to chop off one leg and shave another one. For the injectors if you have a resistor box, then you dont have to. If not change them for b-series.
Old Jun 15, 2003 | 12:40 PM
Hartlage's Avatar
I used a LS dist. on my OBD-0 B16A1 for a few days until my new dist. came in. I had one bolt and a zip-tie holding it on. It ran a little rough and leaked a little oil around the seal, but it worked. I babied my car, so I don't know how well it will work for performance driving. I'm not sure if the OBD-1's are any different.
Old Jun 15, 2003 | 03:51 PM
n1_ek's Avatar
* B A N N E D *
Default Re: (Hartlage)
hey are you saying that.... a OBD1 LS or GSR or Si (B-Series) distributor doesnt bolt up perfectly like all the holes match for the 3 bolts? thanks
Old Jun 15, 2003 | 04:39 PM
mmuller's Avatar
Mad Scientist
Default Re: (ryan819)
the b-series vtec dizzys would bolt right in, but is the non-vtec in wich you gotta cut the legs
Old Jun 15, 2003 | 11:00 PM
n1_ek's Avatar
* B A N N E D *
Default Re: (mmuller)
cool tahts all i needed to know... so i do not need to change the injectors to OBD1? is that right? thanks for the info
JDM Like Whoa
Nov 9, 2006 08:49 AM
ImThatGuy
Oct 11, 2004 08:31 PM
Doodoo
Feb 10, 2003 06:08 PM
EGHatchy
Jul 15, 2002 09:49 PM
