b16a throwing knock. code 23
I have just swapped this motor in 89 civic dx.
I have a feeling it is leaning out, but it might be the wiring ..... I have reset the ecu and no problem and then hit tec, comes right back on.... what should I be looking for symptom wise if it is knocking any way to tell?
The CEL would only come on if the sensor is not working or not wired. Check the sensor itself, mine used to come loose ocassionally and throw a code.
