B16A on an Engine stand....how...?
Old Oct 30, 2003 | 04:51 PM
Gonzo_SiR's Avatar
Default B16A on an Engine stand....how...?
where do you guys stick the fittings from the engine stand...? I got the engine stand they sell thru JCWhitney's.
Old Oct 30, 2003 | 05:05 PM
sweet's Avatar
Default Re: B16A on an Engine stand....how...? (Gonzo_SiR)
i believe i have that same stand.
you will need to get bolts that match the threads of the block and that are long enough to go through the support holes. i personally used extra chassis bolts i had laying around for the top, and bought the bottom ones from a local hardware store. used washers too. also try putting the upper stand portion onto the block while it's not on the stand, that way there isn't as much of a chance to cross-thread the bolts. much easier to lay the block on the ground or workbench and attach the upper section via the 4 bolts, then slide it all onto the stand.
Old Oct 30, 2003 | 05:29 PM
BeerMan's Avatar
Last time I used an engine stand, we had to cut the fittings on the stand down about halfway because we couldn't find the proper length bolts. Just a suggestion.
Old Oct 30, 2003 | 05:39 PM
noble4ws's Avatar
if those didnt help, you bolt the engine stand into where the tranny bolts on just use 4 of the holes best to try and use 4 corners
Old Oct 30, 2003 | 07:36 PM
Tbone's Avatar
Front crossmember bolts off of 88-91civic/crx's work well.
You can see kinda how I mounted mine.
Old Oct 30, 2003 | 09:29 PM
9200RPM's Avatar
I tryed to use a stand..but put down a trash bag on a wood table and built it on there...
Old Oct 30, 2003 | 10:05 PM
IN VTEC's Avatar
Use M12x1.25 bolts for the two upper tranny holes and longer bolts/washers/nuts for the lower unthreaded holes. Take a measurement of the stand's finger lengths and buy a bolt that's long enough from the hardware store.
I also mount our engines the same way as Tbone has illustrated. It distributes the weight more evenly.
Old Oct 31, 2003 | 11:47 AM
sweet's Avatar
Default Re: B16A on an Engine stand....how...? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Use M12x1.25 bolts for the two upper tranny holes and longer bolts/washers/nuts for the lower unthreaded holes. Take a measurement of the stand's finger lengths and buy a bolt that's long enough from the hardware store.
I also mount our engines the same way as Tbone has illustrated. It distributes the weight more evenly.</TD></TR></TABLE>
that's some good info. i also mount the block the same way as Tbone pictured.
works great. BTW, that's one clean block you got there!
Old Oct 31, 2003 | 12:00 PM
Tbone's Avatar
Default Re: B16A on an Engine stand....how...? (sweet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sweet &raquo;</TD></TR><TR><TD CLASS="quote">
. BTW, that's one clean block you got there! </TD></TR></TABLE>
Thanks man , see my sig for the pics of my build.
Old Oct 31, 2003 | 12:20 PM
RCautoworks's Avatar
Good info, saved me some writing. Instead of buying a bolt that is long enough though, I just bought a long bolt rod and cut it to lenght.
Old Oct 31, 2003 | 12:26 PM
sweet's Avatar
Default Re: B16A on an Engine stand....how...? (Tbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man , see my sig for the pics of my build.</TD></TR></TABLE>
yeah, nice looking motor. i saw those pics a little while back. i forgot that was your buildup. it's lookin real good.
so is it all together and running yet?
Old Oct 31, 2003 | 12:45 PM
Wes V's Avatar
I wasn't able to find bolts (M12x1.25) that were long enough and ended up buying a piece of threaded rod from McMasterCarr.
It wasn't cheap!
Wes
Old Oct 31, 2003 | 09:05 PM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">Front crossmember bolts off of 88-91civic/crx's work well.
Looks like he also has the bottom of the blocks milled. All the studs are out and it has a fresh finish on it.
Old Oct 31, 2003 | 11:32 PM
HONDABOND's Avatar
Default Re: B16A on an Engine stand....how...? (TurboB16aEG)
Funny, I did my head the same way... I never realized what an *** it is to get theose little keeprs in.
Old Nov 3, 2003 | 04:23 PM
sweet's Avatar
Default Re: B16A on an Engine stand....how...? (HONDABOND)
if you're talking about Tbone's block in his pic, i believe it's a new Dart block.
that would explain why it's so clean. i was wondering how it was so clean myself til i checked one of his older posts about the buildup.
Old Nov 3, 2003 | 05:33 PM
CleenSi
Guest
Posts: n/a
ALLS U NEED YO IS SUM 4 BIG DUDES N YER SET, U DONT EVEN NEED THAT SHIZNIT YO.
ok, on a serious note do wut the guy sed at top, use a workbench or sumthing of that sort, then CAREFULLY slide it onto the engine hoist.
good luck.
Old Nov 3, 2003 | 07:03 PM
IN VTEC's Avatar
Yeah. I realized that after a while too.
Spawne32
Mar 6, 2010 11:06 AM
Anthrax-VX
May 25, 2004 11:35 AM
Anthrax-VX
Apr 24, 2004 05:43 PM
lildrgn2.0
Jan 28, 2004 06:25 PM
Bnjmn
Mar 2, 2002 08:05 AM
