B16A with CTR pistons
Old Jan 20, 2002 | 03:15 PM
RosebloodSol's Avatar
Default B16A with CTR pistons
Could anyone with some actual numbers on clearance issues with CTR pistons please post them?
I am planning on rebuilding my B16A and I want to use CTR pistons with Skunk2 cams and I have been told by half the people I talk to that I should be worried about valve clearance. The other half have said there is no problem.
So, if you have this setup, or have a reference to actual numbers on valve clearance I would appreciate it.
Thanks!!!
By the way, I also plan on using stock size connecting rods to keep that wonderful ratio.
[Modified by RosebloodSol, 12:16 AM 1/21/2002]
Old Jan 21, 2002 | 06:53 AM
Default Re: B16A with CTR pistons (RosebloodSol)
Does anyone have an idea?
ttt
Old Jan 21, 2002 | 09:03 AM
sgT's Avatar
sgT
valve clearance is not a problem assuming you arent using a milled head and
high lift cams.
Old Jan 21, 2002 | 09:40 AM
Default Re: B16A with CTR pistons (sgT)
This is my planned build up:
Head work:
Skunk2 cams
Skunk2 stainless steel valves
Skunk2 Ti retainers
New valve guides and spring seats
Bottom end:
CTR Pistons
Stock or Eagle rods
No planned milling or decking, and planning on using stock gaskets.
Old Jan 21, 2002 | 09:45 AM
sgT's Avatar
sgT
you should be fine.
Old Jan 21, 2002 | 02:16 PM
Thanks for the input!
How you other guys? Does anyone else have something to add to this?
Come on! Help a guy out!
Old Jan 21, 2002 | 02:48 PM
Red Civic T's Avatar
New User
Portflow head milled .030 and ITR cams and have NO valve interference.
A prob I had that I have NOT seen reported is that the electrodes on my sparkplug & so replaced with shorter Legend plugs....
Old Jan 21, 2002 | 03:03 PM
Default Re: B16A with CTR pistons (Red Civic T)
Are you saying that you had to use shorter spark plugs to prevent problems with clearance? If I read between the lines correctly, you had to replace your stock size plugs with those from an Acura Legend so the pistons did not hit the spark plug electrode after you milled the head by .030.
So, it would seem that I could use the stock size plugs since I don't plan on milling the head. Correct me if I am wrong about your post.
Old Jan 21, 2002 | 03:34 PM
AllMotorMadness's Avatar
that setup shouldn't be a problem at all....I did a b16a setup with ctr pistons, b16a head milled 30k and the car runs fine running with skunk2 cams........ piston to valve clearance wasn't a problem at all...... the motor is stock not built just replace pistons and milled the head
Old Jan 21, 2002 | 03:52 PM
peebrain's Avatar
Default Re: B16A with CTR pistons (AllMotor_2.0L B18C5)
i have stock p30 block, a gsr head milled 40....ctr cams, and the intake is advanced +4...no clearence problems.
anything bigger might be a prob for me, anyone have input on bigger cams for my setup
Waggy
15
Mar 3, 2007 11:20 AM
JUNcr-x
Nov 21, 2003 06:19 AM
P1mpSlap
Jun 4, 2003 08:09 PM
QWKPHKR
Nov 24, 2002 12:03 AM
