B16a cable trans and other gears
Old Dec 3, 2003 | 11:35 AM
K20EG's Avatar
Default B16a cable trans and other gears
Ok i gotta B-16 cable trans ..and im wondering if i can use 99 civic Si internals on this tranny Since i cannot locate the synchros for this tranny i need to get a resolution fast...i have a 99si tranny with a cracked casing ...im wondering if i can use that gear set
Old Dec 3, 2003 | 04:51 PM
K20EG's Avatar
Default Re: B16a cable trans and other gears (K20EG)
ttt
Old Dec 3, 2003 | 05:59 PM
K20EG's Avatar
bump
Old Dec 3, 2003 | 06:19 PM
Kwuaymaikrup's Avatar
The cable B16 trans are small spline. To the best of my knowledge it won't work. You cab get replacement synchros for the trans though. I replaced mine with USDM ones. I should have the part # within a day or two.
-Ryan
Old Dec 3, 2003 | 06:30 PM
K20EG's Avatar
Default Re: B16a cable trans and other gears (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">The cable B16 trans are small spline. To the best of my knowledge it won't work. You cab get replacement synchros for the trans though. I replaced mine with USDM ones. I should have the part # within a day or two.
-Ryan</TD></TR></TABLE>
right ...are they 99si part #'s
Old Dec 3, 2003 | 06:57 PM
^jefs0ng's Avatar
Banned
I'd also like to know!
Old Dec 3, 2003 | 10:41 PM
K20EG's Avatar
Default Re: (.jefs0ng)
bump
Old Dec 3, 2003 | 10:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG &raquo;</TD></TR><TR><TD CLASS="quote">
right ...are they 99si part #'s </TD></TR></TABLE>
I don't have the part # in front of me but PM "Mochanic" he will be able to help ya. Just tell him I sent ya.
-Ryan
Old Dec 4, 2003 | 06:18 AM
(JON)'s Avatar
going strictly from what ive heard(i have no factual evidence) on the older smaller spline bseries transmissions, some parts from the 92-up dseries tranny's are interchangable. i will look into this more but i thought id give you a heads up and you could research the possibility also!
Old Dec 4, 2003 | 06:24 AM
(JON)'s Avatar
okay i found a link... http://courtneyeg9.streetracin....html
Old Dec 4, 2003 | 09:53 AM
K20EG's Avatar
Default Re: B16a cable trans and other gears (DaStyle)
yea ...that is very helpful thank you
imma have to try and see if i can use all 99si internals
Old Dec 4, 2003 | 09:17 PM
K20EG's Avatar
bump
Old Dec 5, 2003 | 07:17 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG &raquo;</TD></TR><TR><TD CLASS="quote">yea ...that is very helpful thank you
imma have to try and see if i can use all 99si internals </TD></TR></TABLE>
you're just gonna waste your time, they do not work. the synchros on the 00 vtec tranny are much bigger that the jdm ones, they just won't work take my word for it!
Old Dec 5, 2003 | 10:31 AM
Default Re: B16a cable trans and other gears (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
you're just gonna waste your time, they do not work. the synchros on the 00 vtec tranny are much bigger that the jdm ones, they just won't work take my word for it! </TD></TR></TABLE>
Agreed...the input shaft on the older trans is smaller than the 92+ shafts.
-Ryan
Old Dec 6, 2003 | 02:01 AM
Mista Bone's Avatar
D Tranny Guru
bump those parts right into the trash can.
Spend time SEARCHING, not bumping.
scooterbuilteh2
Jan 9, 2010 04:38 PM
redboy183
Oct 11, 2008 06:17 AM
ef9civicgen4
May 29, 2008 03:26 AM
EJ_ALLMOTA
Oct 22, 2007 07:17 PM
91-lsvtecsi
Aug 11, 2006 06:27 PM
