b16 transmission problem
Old Jan 21, 2007 | 08:49 PM
IntegR's Avatar
Default b16 transmission problem
About to have a quick race when i Revved my car to about 2500 rpm let go the cluch and car wasnt moving (wheelspin) shifted into 2 gear car just made alot of noise...then my clutch wouldnt come up it was stuck..couldnt shift into any gear..so i turn my car off and managed to get it into gear..then cluth pedal was starting to feel normal again but it makes a whining noise when im trying to put it into gear..smelled like horseshit!!! horrible by the way..and i have a 7.5 fidanza so car revved to about 8k rpm...HELP...also new clutch has about 3 month installed...oops forgot to mention my third gear was grinding some times..HELP lol
Old Jan 21, 2007 | 09:21 PM
OG undercover's Avatar
Default Re: b16 transmission problem (IntegR)
Ohhhh!!! Where were you racing?
Old Jan 21, 2007 | 09:33 PM
IntegR's Avatar
Default Re: b16 transmission problem (Mr. CRYBABY)
Yeah I was trying to until my flywheel fucked me over..I called my mechanic and he also told me he put gear oil instead of honda mtf..think I'm pretty screwed..
Old Jan 21, 2007 | 10:30 PM
Stoich EG2's Avatar
you should take the tranny out to inspect damage. Maybe a flywheel bolt came loose
Old Jan 22, 2007 | 06:33 AM
robfrmny21's Avatar
your mechanic is a ******* dick head for telling you to put gear oil in you trans, at most you could use a light weight engine oil not heavy gear oil that ***** the tranny up.... put honda oil in it and let it run and see if any thing got fucked up be4 you remove it... what a tool he is
Old Jan 22, 2007 | 07:43 AM
IntegR's Avatar
Default Re: b16 transmission problem (robfrmny21)
yeah i know he fucked up..he will install my next clutch for free for that expletive up..but i went to him this morning and said the clutch is fucked up..anyway i probably end up taking the fidanza fw off..anyone selling a oem type r FW?
Old Jan 22, 2007 | 07:48 AM
IntegR's Avatar
bump
Old Jan 22, 2007 | 10:24 AM
cypressink's Avatar
1) 3rd gear grinds on B16 trannies, it is a known problem. not realyl fixable.
2) shoulda used Honda MTL, I heard not to mess with that stuff from the owner of Redline motor oil. He said Honda's doing some werid stuff. Let the mechanic check the clutch and fly and make sure your tranny is alrite. if it isn't make him buy you a new one cuz he messed up. good luck.
Old Jan 22, 2007 | 11:54 AM
IntegR's Avatar
Default Re: (cypressink)
thanks
Old Jan 22, 2007 | 02:13 PM
IntegR's Avatar
Default Re: (IntegR)
Bump
Old Jan 22, 2007 | 09:37 PM
MikeSarr_GSR's Avatar
remove your tranny. forget the cheap fixes. knowing the problem is
better than black magic only other people can perform.
jdmej814
Jul 26, 2009 05:05 AM
nus_dogg
Mar 25, 2009 07:53 PM
SkIp_Civic_Ek6
Apr 5, 2007 11:38 PM
4everVtec
Oct 4, 2006 02:56 PM
IMMORTAL-B18
Jun 26, 2004 02:36 AM
