b16 timing, need help asap Look!!! :-P
Old Oct 23, 2003 | 01:33 PM
doublejz's Avatar
Default b16 timing, need help asap Look!!! :-P
Is that the timing line on the timing belt cover?
Crank Pully in time, i think? now about the cam gears.
so my cam gears shouldn't be like this then. I should set them straight across??
So I should loosen the belt and straighten the cam gears? I just thought TDC would be straight up and down. like on my old d16z6
Modified by doublejz at 7:07 AM 10/28/2003
Old Oct 23, 2003 | 01:39 PM
importfan's Avatar
the three marks on the pully are for ignition timing the white mark is for tdc, as for the cam gears I don't know off hand
Old Oct 23, 2003 | 01:45 PM
doublejz's Avatar
Somebody???
Old Oct 23, 2003 | 01:49 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: b16 timing, need help asap Look!!! :-P (doublejz)
those came gears are off in the pics the white line to the far right on the pully should be lined up with the mark on the cover..and the cam gears should have the "up"marks pointing up and the 2 dots on the inner ends of the cam gears should be lined up across from eachother.
Modified by bruceleeroy at 6:03 PM 10/23/2003
Old Oct 23, 2003 | 02:43 PM
AzG35's Avatar
Default Re: b16 timing, need help asap Look!!! :-P (bruceleeroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">those came gears are off in the pics the white line to the far right on the pully should be lined up with the mark on the cover..and the cam gears should have the "up"marks pointing up and the 2 dots on the inner ends of the cam gears should be lined up across from eachother.
This is correct, the white line is TDC, not the red line. Also, the all the marks on the cam gears should be in a straight line, I use a piece of cardboard sometimes to make sure they are. The UP should be readable from left to right as well.
tinyscivic
Mar 9, 2010 09:03 PM
kixcrx
Sep 28, 2007 12:35 AM
realis9
Feb 21, 2007 06:12 AM
lsvtec101
Apr 26, 2004 11:28 AM
