B16 swap nit-picking
Old Nov 11, 2003 | 01:48 PM
notstock93's Avatar
Default B16 swap nit-picking
I have a new b16 block (mmm.....0 miles) and I need to go find a b16 head. What will swap over from my OBD-I B18a head? I will get a OBD-I head, obviously, but will the injectors switch? fuel rail? sensors? AEM accesory pulleys? Just name some things that WONT bolt up, thanks in advance.
93 Integra LS.
Vince
Old Nov 11, 2003 | 04:34 PM
notstock93's Avatar
Default Re: B16 swap nit-picking (notstock93)
C'mon....
Old Nov 11, 2003 | 04:37 PM
mmuller's Avatar
Mad Scientist
all the sensors will bolt up, dizzy(if you cut one of the legs off), pretty much everything
Old Nov 11, 2003 | 04:51 PM
notstock93's Avatar
Default Re: B16 swap nit-picking (mmuller)
fantastic, what about the existing vaccum lines on the firewall? Do you have anything I should watch out for (red buttons im not supposed to press...etc)?
Old Nov 11, 2003 | 05:04 PM
iwhichisme's Avatar
what kind of b16a
Old Nov 11, 2003 | 07:20 PM
notstock93's Avatar
Default Re: B16 swap nit-picking (iwhichisme)
b16a3 out of a Del Sol . OBD-I and probably going to be eqquiped with my old hondata and some type-r cams. My old b18a had alot of stuff done do it. Does anyone know the belt length ill need for a b16 with AEM underdrive pulleys with a b18 crank pulley? Im not looking foward to the trial and error part of the install.
Anyway, Im really worried about vacuum leaks and ignition problems, those are my two pet peeves.
jorgejam2001
Sep 20, 2010 07:21 PM
avblueshark
Aug 29, 2009 02:10 AM
S.Celia
Jan 31, 2004 12:34 AM
