B16 head plug - Where would I find this? Is there a replacement?
Old Oct 18, 2018 | 10:29 AM
boostedblue23's Avatar
Default B16 head plug - Where would I find this? Is there a replacement?
So I went and started my car and realized oil was pooring our everywhere. Shut it off and realized there was a threaded hole on the head it was coming from. I need help finding this plug or even what it’s called. Here’s a picture of what I need.
Old Oct 18, 2018 | 10:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B16 head plug - Where would I find this? Is there a replacement?
1/8" NPT pipe plug. Easy Peasy.
Old Oct 19, 2018 | 03:08 AM
Thanks sir! Still pissed all the oil is under the car in a new driveway 🤦🏻*♂️.
Old Oct 19, 2018 | 09:11 AM
TheShodan's Avatar
Moderator
Nice catch.. Never knew that (although I never needed a replacement for it)
Old Oct 19, 2018 | 11:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
They are usually a real MF'er to get out... leaving them alone is the best idea.
Old Oct 19, 2018 | 11:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I bet that made a REALLY BIG mess !!! So now you have a really dirty fresh engine and stained fresh concrete... sorry man.
Old Oct 21, 2018 | 07:13 AM
Yeh made a huge mess. Only reason I’m messing with it is the machine shop forgot to put it back in. Hopefully motor isn’t hurt. Ran it for about 15 seconds before I realized all the oil was under the car. Should be fine.
Old Oct 21, 2018 | 09:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Long term engine damage is unlikely if you only ran it for 15 seconds... the puddle on the ground will look giant but it is likely that only a quart or two got pumped out... leaving at least two or three quarts to lubricate the engine... at least the bottom end anyway. You can check the cam journals for galling... if they look good, you should be fine.
NIKADEM0
Sep 19, 2013 07:05 PM
CRXguy_88
Jul 14, 2011 01:40 PM
Cruzan77
May 10, 2009 08:06 PM
hybridpatient95
Jan 24, 2007 04:00 AM
91-lsvtecsi
Mar 23, 2006 03:41 PM
