B16 Head Plug?
Old Sep 19, 2013 | 10:07 AM
NIKADEM0's Avatar
Default B16 Head Plug?
I am trying to finish piecing this engine together and get it running. This is a B16 head on my B18C block. Can anyone tell me what that open threaded hole is in the middle of the picture, to the left of the dizzy??? Do I just plug it? I can't find it on any dealership's website :-(
Old Sep 19, 2013 | 10:15 AM
kyden's Avatar
Default Re: B16 Head Plug?
it is the plug you take out for an ls/vtec. did you remove the pipe thread from the deck surface?
Old Sep 19, 2013 | 10:23 AM
NIKADEM0's Avatar
That's how my motor came. I haven't done anything to it. It's missing stuff. So you can verify a plug does go there? I want to know how that comes from Honda.
Old Sep 19, 2013 | 10:47 AM
elmanre's Avatar
Yes, you need to plug or search for something to plug there, if you don't, you are going to have an oil party inside your engine bay
Old Sep 19, 2013 | 01:18 PM
B_Swapped93's Avatar
was just about to say that guess someone had that head for an LS/B20V. I think a bolt with lock tight would work don't quote me on that that's just what I would do.
Old Sep 19, 2013 | 02:44 PM
IN VTEC's Avatar
It's 3/8" BSPT.
Old Sep 19, 2013 | 02:56 PM
elmanre's Avatar
Also Important, hope you didn't mount the head before checking the oil pickup line under, if it was used for ls vtec before, maybe is blocked.
Old Sep 19, 2013 | 04:16 PM
NIKADEM0's Avatar
Originally Posted by IN VTEC
It's 3/8" BSPT.
Just like the oil pressure sending unit? Could I use that oil for my turbo's oil line? Seems like it's meant to be!
Old Sep 19, 2013 | 04:18 PM
NIKADEM0's Avatar
Oil pickup line under? I thought that was on the block? I got B18C V-TEC block. The head has been bolted down with a new head gasket and arp head studs. I bought it as a long block pretty much. It's missing a lot though :-(
Old Sep 19, 2013 | 04:35 PM
sirtef9's Avatar
http://www.bing.com/images/search?q=...lectedIndex=46
see the allen head in the head on the left?
If it's plugged you will never have vtec.
It's probably plugged if it was an ls/vtec setup.
Old Sep 19, 2013 | 04:43 PM
NIKADEM0's Avatar
****. I think I may have to take the head off to be certain.... FML
Old Sep 19, 2013 | 07:05 PM
sirtef9's Avatar
^ Yea no way else to see it lol
boostedblue23
Oct 21, 2018 09:18 PM
CRXguy_88
Jul 14, 2011 01:40 PM
Cruzan77
May 10, 2009 08:06 PM
91-lsvtecsi
Mar 23, 2006 03:41 PM
White_EK49
Sep 27, 2005 05:16 PM
