B16 going into limp no cel???? help
Old Oct 19, 2003 | 09:27 AM
vtec_r's Avatar
Default B16 going into limp no cel???? help
When I am just driving along and my civic will go into Limp mode and run full rich. When I push in the clutch during this it will Die. If I shut it down and remove the key and then start it agian it will be fine Help please. No codes
99-si I/H/E - 7 lb fly - exeddy clutch - fields(stock settings)
Old Oct 19, 2003 | 11:17 AM
sleepyEK's Avatar
Default Re: B16 going into limp no cel???? help (vtec_r)
your cel might not be functioning, so hook a pgm up to it and pull the code, if there isn't a code, check your data stream and find out what's weird, it could possibly be your ecu, but i don't know the details of your problem.
slowesteg
May 11, 2012 11:07 PM
afstvx
Jan 9, 2008 06:03 PM
95LStizzy
Mar 1, 2006 06:29 PM
1SpoolnH
Jun 9, 2003 07:27 PM
