b16 and b18 block from same cast?
Old Feb 3, 2003 | 09:20 AM
infamousALLMTR's Avatar
Default b16 and b18 block from same cast?
I was wondering for the sake of an Idea, I was under the impression that if you put a b18 ls crank in a b16 block and had ls pistons/rods that it would be essentially a b18 block. Was the b16 block designed specificly for the b16 crank? I have heard of the b17 crank going in the block and stroking it that way. Would you need to do something the the ls crank to make it work in a b16?
thanks for any help
mike
Old Feb 3, 2003 | 09:47 AM
texan's Avatar
Default Re: b16 and b18 block from same cast? (infamousLSVTEC)
Main bearing diameter and the like are mostly standardized over the B series engine range, but deck height and bore aren't. The B16 has the shortest deck height in the B series lineup, so LS pistons and rods on that crank would be well above the deck at TDC.
[Modified by texan, 10:48 AM 2/3/2003]
Old Feb 3, 2003 | 01:16 PM
SiRkid's Avatar
Default Re: b16 and b18 block from same cast? (texan)
well bore isthe same.. its just the the b20 that is diff.
[Modified by SiRkid, 10:16 PM 2/3/2003]
Old Feb 3, 2003 | 02:18 PM
Default Re: b16 and b18 block from same cast? (SiRkid)
but you can put a b17 crank in these blocks right?
Old Feb 3, 2003 | 02:25 PM
owen_the_soyboy's Avatar
you can put any B series crank in any B series block, it depends on the RODS that you use as far as whether or not you will pop the head off
Old Feb 3, 2003 | 06:12 PM
irev210's Avatar
b17 and b16 are from the same cast
just different crank, rods, pistons
but the deck height is taller on the b18, different motor
has different casting also, doesnt have the strong webbing thats found on the b16/17
hope this helps
vtec8200
11
Jun 13, 2011 10:04 AM
Project_SOHC_EX
Nov 10, 2009 10:48 AM
dc4b20
May 9, 2008 12:46 PM
hondacivic0909
12
May 6, 2007 01:49 PM
CircuitFG
May 4, 2005 01:19 AM
