B-series vtec primary cam specs
Old Jun 22, 2003 | 03:39 PM
boosted92's Avatar
Default B-series vtec primary cam specs
Wondering if anyone can give me the specs on the primary (I think that's what it's called, but whatever the non-vtec lobe is called) lobe on GSR cams? INT/EXH lift, duration, and LSA please.
Old Jun 11, 2004 | 09:44 AM
Shu's Avatar
Shu
Default Re: B-series vtec primary cam specs (boosted92)
Anybody have this information?
Old Jun 12, 2004 | 12:07 AM
Rocket's Avatar
Default Re: B-series vtec primary cam specs (Shu)
I just recently cam doctored some B16 Auto intake cam primaries.
Primary:
Valve Lift: 0.146"
Cam Lift:0.104"
Duration at 0.050" lift: 132 degrees
Secondary:
Valve Lift: 0.297"
Cam Lift:0.205"
Duration at 0.050" lift: 184 degrees
GSR primaries will be a lil bigger than these numbers.
Old Jun 16, 2004 | 09:51 AM
Shu's Avatar
Shu
Default Re: B-series vtec primary cam specs (Rocket)
I just found out that these numbers are actually published in the Helms. I have the 1990 civic v-tec supplement (B16) so I'm posting those numbers below (page 5-6). Can someone with an Integra Helms please post for the B18C1?
Intake A lobe: opens at 10* ATDC, closes at 30* ABDC, lift 8.0mm
Intake C lobe: opens at 20* ATDC, closes at 20* ABDC, lift 5.0mm
Exhaust A lobe: opens at 20* BBDC, closes at 20* BTDC, lift 4.5mm
Exhaust C lobe: opens at 30* BBDC, closes at 10* BTDC, lift 7.5mm
VTEC intake lobe: opens at 10* BTDC, closes at 40* ABDC, lift 10.4mm
VTEC exhaust lobe: opens at 40* BBDC, closes at 5* ATDC, lift 9.4mm
Modified by Shu at 2:03 PM 6/16/2004
Modified by Shu at 2:25 PM 6/16/2004
brandonschmidt
Dec 27, 2009 07:34 AM
Ekasey
Honda S2000
Aug 10, 2006 12:04 PM
T_bones
Dec 16, 2005 12:22 PM
BryanPendleton
Dec 11, 2004 07:31 PM
