B series flywheels.. specs for machining, etc?
Old Dec 12, 2001 | 08:27 PM
slow_civic's Avatar
Default B series flywheels.. specs for machining, etc?
just how much can you take off of a late gsr flywheel?
does anyone have the specs? anybody done it?
TIA
Old Dec 13, 2001 | 07:04 PM
slow_civic's Avatar
Default Re: B series flywheels.. specs for machining, etc? (slow_civic)
Old Dec 14, 2001 | 09:36 PM
slow_civic's Avatar
no one has done this?
Old Dec 15, 2001 | 06:35 AM
WAFFLES's Avatar
It's wise to not machine much off at all. Are you talking about shaving some weight off or just resurfacing. If your just resurfacing, just go till it's flat. DO NOT LIGHTEN YOUR OWN FLYWHEEL!
Old Dec 15, 2001 | 02:22 PM
ToneyTigre's Avatar
New User
Default Re: B series flywheels.. specs for machining, etc? (WAFFLES)
if your talking about resufacing. step dimensions should be 2.75mm or 0.108 inches
if your lightening it, i would just buy a lighter flywheel if i were you. it screws up the integrity of the flywheel. a cheap alterative is to buy a used itr flywheel.
Old Dec 15, 2001 | 04:07 PM
slow_civic's Avatar
Default Re: B series flywheels.. specs for machining, etc? (ToneyTigre)
hmm.. no, i was talking about taking weight off. somewhere i read that you could take a few pounds off and have it still be safe.
Old Dec 15, 2001 | 11:58 PM
Def's Avatar
Def
Just get a new flywheel that is lighter. Everybody I know that's done this usually just goes a step further and gets a lighter flywheel later, and they wish they had done that first.
You will affect the integrity of the stock piece, and you could probably only take off 2-3lbs and have it not completely fly apart on you immediately. So it will only give you a taste of what a real lightened flywheel feels like.
Light flywheel = nothing but good things in a Honda
To a point that is, I think the 6lb jobbers that some companies sell are bordering on too light. 10-11lbs is perfect IMO.
Old Dec 16, 2001 | 04:50 PM
slow_civic's Avatar
Default Re: B series flywheels.. specs for machining, etc? (Def)
the advantage i have is that my brother has access to a machine shop, so, if i could get the specs somewhere it would cost me nothing. i doubt i'm going to mess with it, though.
cr8ter
Transmission & Drivetrain
Oct 17, 2009 09:31 PM
Jabinya
Apr 21, 2007 05:11 PM
akura404
11
Apr 15, 2006 12:19 PM
EJ8 GSR-T
Jan 30, 2006 10:34 AM
IN VTEC
May 7, 2002 04:15 AM
