B-series Engine Mount Question
Old Mar 25, 2003 | 04:03 PM
RyanAutry's Avatar
Default B-series Engine Mount Question
Is it necessary to have the A/C Mount if you don't have AC? I noticed this car doesn't.
http://www.jdmcivic.com/photopost/da...abunai-med.jpg
[Modified by RyanAutry, 5:04 PM 3/25/2003]
Old Mar 25, 2003 | 06:26 PM
TimoneX's Avatar
New User
Default Re: B-series Engine Mount Question (RyanAutry)
Well your pic doesn't work, but the AC mount has that motor mount coming off of it, more like a stabilizer since it doesn't bear a huge amount of weight, but I'd bet your motor will torque a bit more w/o that mount costing you a bit of power.
Old Mar 25, 2003 | 06:29 PM
Nameless RB26's Avatar
Default Re: B-series Engine Mount Question (TimoneX)
Yah you need it. Not a mount, but a bracket.
AC compressor bolts onto it.
Old Mar 25, 2003 | 10:26 PM
RyanAutry's Avatar
Old Mar 25, 2003 | 10:27 PM
RyanAutry's Avatar
Default Re: B-series Engine Mount Question (Nameless)
Well I don't have AC.
Old Mar 25, 2003 | 11:05 PM
RangerDan's Avatar
Yeah you need it on most applications. With some 5th Gen civics without it the engine will sometimes hit the hood under power.
Its not really a weight bearing mount but it keeps the engine from rocking back and forth when punched.
Old Mar 26, 2003 | 04:45 AM
BROOD's Avatar
You should run all the engine mounts...including the two forward torque mounts. They are there for a reason.
Old Apr 29, 2003 | 02:48 AM
blufke's Avatar
Default Re: B-series Engine Mount Question (SLPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLPR &raquo;</TD></TR><TR><TD CLASS="quote">You should run all the engine mounts...including the two forward torque mounts. They are there for a reason. </TD></TR></TABLE>
for a hood denting reason.
Old Apr 29, 2003 | 06:27 AM
94CivicSi's Avatar
Default Re: B-series Engine Mount Question (blufke)
If you don't have AC, you can run the Integra P72 AC bracket. They're much more common than the Del Sol P54 bracket which accepts the Civic compressor and therefore, much cheaper. I have an extra P72 WITH the mount if you're interested.
prison_snitch
Jun 9, 2006 01:32 PM
spock_rocker
10
Jul 30, 2005 05:17 PM
rasinhell
Mar 18, 2005 08:45 AM
jolt-tsp
Feb 24, 2004 01:14 PM
mingchi69
Aug 13, 2003 11:15 AM
