Axle Squeek
Old Oct 22, 2004 | 07:18 AM
Tchleung's Avatar
Default Axle Squeek
So I installed a new axle into my sister's 1986 Honda Accord EX-i VERY straight forward as I've done it many times and it's just an axle, couple bolts and your done. Anyways. After I installed everything and went for a drive, the car keeps making a "squeak" sound. it pulses like squeek squeek squeek with the speed you are going. the faster the speed. the louder and faster it gets. oh, obvious there. I musta pushed the rotor plate in. Checked it... perfectly fine(cause I remember specifically avoiding bending it) So I check around the new axle and nothing is rubbing... I've checked everythnig I touched and cna't figure it out.. It's a Fenco reman axle.. I am starting to wonder if the axle itself is bad or something... I am gonig to warranty it and replace it with another one to give it a try. But if anyone has any other ideas that'd be great. BTW it's passenger axle.
Old Oct 22, 2004 | 09:08 AM
Tchleung's Avatar
TTT
Old Oct 22, 2004 | 09:14 AM
spoonek9's Avatar
Default Re: (Tchleung)
Are are the brake pads??
Old Oct 22, 2004 | 10:01 AM
Tchleung's Avatar
No it's not comnig from the brake pads. Not like I touched them anyways and I'm pretty sure they are not slightly contacting
Old Oct 25, 2004 | 04:52 AM
Tchleung's Avatar
Found out what it was.. one of the metal clamps on the inner axle by the diff taht held the boot on was hitting the tranny case till it broke off one day and the noise stopped. luckily the boot didn't slide off. I didn't have a clampe tc, so I jsut repalced it with a whoel new axle, btu prior to it I hammered the clamp thing downa bit where it buldeged out alot and now it doesn't hit. thanks for the help tho.
cmasino
Honda Civic (2001 - 2005)
Jul 14, 2017 10:44 AM
PhiLLyMYdiLLy
Mar 16, 2017 09:38 AM
Da4yoA$$
Aug 26, 2010 07:17 AM
20-EM2-05
Feb 5, 2010 11:05 AM
...Baker
19
Aug 14, 2006 09:59 AM
